Shift tower bolt size - JeepForum.com
post #1 of 5 Old 03-04-2014, 08:44 AM Thread Starter
Tarpo
Seem to have misplaced the shift tower bolts for my ax15. Anyone know off hand what size those bolts are??
The 4 bolts that hold the shift tower to the trans.
88 yj. 95 4.0 4 Brl carb, Msd ignition, offenhouser intake, headers. Ford 8.8 rear end, sun fire seats. About to install a newer ax 15 to replace my tired ba10.
Tarpo is offline
post #2 of 5 Old 03-04-2014, 10:31 AM Thread Starter
Tarpo
Didn't go ad any but I found this online in case anyone else has the same problem
They are just regular 8MM X 1.25 thread pitch bolts. The 2 on the passenger are standard bolts, about 30MM long. The 2 on the driver's side have a "stud" built into the head about 20MM tall. You could use a 50MM bolt with the head cut off and 2 nuts (1 to fasten the shift tower & 1 to attach the T-case shifter bracket) for each of the driver's side bolts.
Tarpo is offline
post #3 of 5 Old 03-04-2014, 01:41 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Can't confirm the 8 X 1.25 until I get home and check the transmissions I have laying in the garage. Yes, 2 of them have a threaded stud above the head, but on mine, I have not had anything that connects on top of those threaded studs like a wire loom, etc. Truthfully I have not had to pull anything off of there on the numerous AX 15s I have yanked so I don't really know their purpose. I wouldn't mind someone telling me what the intended purpose is. Unless your setup was different, you can just go with standard hex heads and call it good.
I have seen these type fasteners referred to as Hex head stud bolts.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 5 Old 03-04-2014, 03:06 PM
imstillatwork
On an AX5 at least, the studded bolts are there to attach the transfer case shifter.
On the AX15 I used them the same way to make the AX5 transfer case shifter work on the AX15.
imstillatwork is offline
post #5 of 5 Old 03-04-2014, 09:23 PM
Opihi59
Opihi59's Avatar
Interesting.........I haven't pulled off an AX 5 yet. Thanks for posting in.
Opihi59 is offline
