Shift motor on Dana 30 - JeepForum.com
post #1 of 7 Old 04-15-2002, 08:05 PM Thread Starter
Coot
I checked the shift moter for the lockouts on my 92 YJ with a vac pump as the Chilton's manual says. Seems it works fine, but it never unlocks.I looked over the vac lines to the transfer case seems ok. When the vac lines are unhooked the lockouts disengage. Any ideas on why the thing isn't working?
92 Jeep YJ, 4 Banger, Cold air intake, Electric fan, 1 inch motor mount lift, 8.8 rear axle Limited Slip 4.10's, SOA, 2 inch body, 35x12.5 Pro Comp MT on 15x8 AR-767
Coot is offline
post #2 of 7 Old 04-15-2002, 08:29 PM
Bob K
Bob K's Avatar
In order to disconnect one of the vacuums must release vacuum. Look for a clogged line. Or replace the vacuum switch on the transfer case. I think it costs less than $10 and takes a few minutes to change.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 7 Old 04-21-2002, 07:21 PM Thread Starter
Coot
Could someone take a look at there vac lines.
Two go from the shift motor and two more come from the engine compartment all four to the transfer case. Here is where I need help, up in the engine compartment one goes to the throttle body which makes since. But the other loops behind the battery tray. Should this one be hooked to something? this is on a 92 YJ with a 2.5 5 speed. Thanks...
Coot is offline
post #4 of 7 Old 04-22-2002, 06:29 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
the one going behind the battery tray is a vent, and should have a plastic protector to keep dirt out. thats it
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #5 of 7 Old 04-22-2002, 09:21 PM
Wildbill
Wildbill's Avatar
Hey Coot,
I had problems with my '92 YJ right after I bought it and I went crazy looking for a proper picture of the vacuum harness. What I concluded was that four lines come from your T case. 1 goes to your vacuum manifold, 1 goes over to the battery area and is a vent and should be bent down. the other 2 go to the motor. 1 engages and 1 disengages. Can't remember which is which right now but is easy to figure out.
What I did was to raise all 4 wheels off the ground and place on jack stands. Engage your T case and see if your front axle engages. You can also do this manually with a vacuum checker.
What I discovered is that the vac motor will seize if you don't use regularly. Don't buy one from the dealer if it is bad you can get the same Spicer/Dana motor from 4wd hardware for about $100 buck less. Hope this helps e-mail if you still need anything explained.
Yale H.
Club President
Peace River Jeepers
Blue Jeep Club Member #23
'92 Blue YJ 4.0 HO, 5spd.
'04 Bright Silver Liberty Sport 4X4 3.7L Stock for now
What do a Divorce in Alabama, A Tornado in Kansas and a Hurricane in Florida all have in common?.....No matter what someone is fixin' to lose a trailer
Wildbill is offline
post #6 of 7 Old 04-22-2002, 09:55 PM
bigjeep39
bigjeep39's Avatar
<img src="http://www.binaryinc.org/images/jeep/jeep_vac_diagram.jpg" alt="" />
HOPE THIS HELPS
1998 TJ
Slow steady project.
bigjeep39 is offline
post #7 of 7 Old 04-25-2002, 06:03 AM Thread Starter
Coot
Thanks everyone,now off to Clayton this weekend.
Coot is offline
Vacuum shift motor dkross YJ Wrangler Technical Forum 17 12-27-2010 07:09 AM
Vacuum shift motor shansel88 YJ Wrangler Technical Forum 6 02-06-2010 09:19 PM
Wires on the shift motor? spawkum YJ Wrangler Technical Forum 21 12-29-2008 09:09 PM
dana 30 shift Motor. irdaniel YJ Wrangler Technical Forum 1 06-30-2005 11:44 PM
need a web link for a shift motor jeep75 YJ Wrangler Technical Forum 4 09-20-2004 04:58 PM
