Shift Light - JeepForum.com
post #1 of 6 Old 10-23-2002, 08:08 AM Thread Starter
bamajeep
bamajeep's Avatar
Shift Light
Does the shift light on the dash in front of the steering column on a 94 YJ come on according to timing or rpm's ? I never use it anyway i was just wondering if this is a way to tell if the timing is off. Also I have oil blowing out either in front of the oil pan or the pulley on bottom of the motor. Could this maybe be a oil pan gasket or front main seal ?
bamajeep is offline
post #2 of 6 Old 10-23-2002, 08:41 AM
Jeepfreak81
Jeepfreak81's Avatar
Im not certain how it works, but i don't think it is by rpm... granted mine always comes on around 2-2200 rpm, but if you mat it to the floor it goes off, i think somehow the cpu compares rpms to speed -- if you hold a constant speed and the engine winds a little it tells you to shift, your timing if you have the 2.5 is computer controlled and you can't really adjust it from what i have found. I don't know how it works with the 6 cyl. I doubt this helps any but i never know
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #3 of 6 Old 10-23-2002, 10:32 AM Thread Starter
bamajeep
bamajeep's Avatar
Thanx, Jeepfreak81. If i shifted like the light says to, I would be luggin' up all hills. I probably could get someone to hook it up to a computer to check the timing.
bamajeep is offline
post #4 of 6 Old 10-23-2002, 11:01 AM
Jeepfreak81
the light is to shift when you get the best mileage, mine lugs a little if i shift when it says to as well, they all do a little. hth
post #5 of 6 Old 10-23-2002, 02:23 PM
UniSonic23
the light comes on from vacuum pressure
'97 Flame Red TJ Stock 4.0l
w/30 X 9.5 Kelly Safari AWR
2003 Model Center Console SUB
Soft and Hard Top
UniSonic23 is offline
post #6 of 6 Old 10-23-2002, 02:27 PM
UniSonic23
jake yours lugs all the time
AKA 4 angry squirrels (4 banger)
test it out.... when you push down on the accelerator...the vacuum pressure changes and the light goes out becuase you are accelerating....if you just drive at high r's your light will stay on because you vacuum pressure is high.
i actually had my shift light come on in 5th grear a few times...i don't know how to make it do it but it was wierd.
Soft and Hard Top
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 08:29 AM
Following the Shift Light LandoCommando TJ Wrangler Technical Forum 24 01-16-2008 01:18 PM
TJ Shift Light - In 5th!? hikerpaddler TJ Wrangler Technical Forum 6 11-13-2005 06:03 PM
shift light... head27 TJ Wrangler Technical Forum 12 06-21-2002 02:10 AM
Shift light Ronnie Bravo TJ Wrangler Technical Forum 3 03-17-2002 06:52 PM
