shift knob - JeepForum.com
post #1 of 4 Old 05-20-2010, 08:47 PM Thread Starter
jth0033
1987 YJ Wrangler
shift knob
I was looking online and I saw how someone used a pineapple dummy grenade to make a t-case shift knob. I was interested more in creating a auto shift knob for the column, since i've never had a knob anyway. does anyone think this will work or know the thread size? thanks for the help either way
jth0033 is offline
post #2 of 4 Old 05-20-2010, 11:54 PM
Opihi59
from here it gets rough
Opihi59's Avatar
It's always good to have a knob. Sure this should work, so long as the end of the column shift is threaded, or if you have a tap and die set, you can thread it yourself. If your shaft is threaded, and you don't have a thread gauge, you can dig into your "box-o-nuts and bolts" and trial fit until you find the match, then take that nut to your local hardware store and test fit in a variety of bolts til you find the thread size/pitch.
I honestly don't know if the knob screws off on the column shifter on autos, or if it is splined on, but if you find it isn't and have your own tap and die set, then thread it to the closest fit for the diameter of the shaft and then figure out what you can stuff on it.
Good luck.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 4 Old 05-21-2010, 05:44 AM
muddy93
1987 FSJ Wagoneer
I don't know how heavy those "dummy grenades" are, but if you put to much weight on the end of the shifter, it might pop out of gear whenever you hit a bump.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #4 of 4 Old 05-21-2010, 06:08 AM Thread Starter
jth0033
1987 YJ Wrangler
i actually believe it might be splined on.... anyway that i could still do this haha
thanks muddy i didn't even think about that... i might have to check the weight
looks like i'm gonna have to make a trip to the army navy store haha
jth0033 is offline
Where can i get this shift knob. dimaxxxl Wrangler General Discussion 10 12-12-2016 12:24 PM
Anybody have a "Monster knob" shift knob? Igetit TJ Wrangler Technical Forum 1 06-01-2009 09:15 AM
YJ Shift Knob Johnny World YJ Wrangler Technical Forum 3 03-11-2006 07:49 AM
shift knob NPerry05X TJ Wrangler Technical Forum 17 08-23-2005 09:46 AM
Shift Knob Off-Road Kid TJ Wrangler Technical Forum 3 02-23-2003 04:57 PM
