shift grind SOMETIMES - JeepForum.com
post #1 of 5 Old 08-12-2011, 06:50 PM Thread Starter
ikircher
Hello all!! I am stumped. I have a 95 wrangler with the i4 and 5-speed. When i shift from 1st to 2nd like normal, there is a grind. If I shift from 1st, then act like Im going to put it in 3rd, then go to 2nd, there is no grind. I dont actually put the shifter into 3rd, i just push it up near there then go into 2nd. Whenever i do this, there is no grind. I changed the trans fluid to redline mt90 to hopefully help somewhat but it didnt. Anyone have any ideas?
Thanks!!
ikircher is offline
post #2 of 5 Old 08-12-2011, 08:00 PM
yj98joe
Try changing the trans oil. It sometimes helps. Shift little slower.
Edit: sorry, you already did that. Sounds like the syncro's are worn out. eventually it will need to be rebuilt. nurse it for now.
yj98joe is offline
post #3 of 5 Old 08-12-2011, 08:15 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Worn out syncros. Time for you to learn to rebuild it.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 5 Old 08-12-2011, 08:24 PM Thread Starter
ikircher
Max
i have an extra trans in my garage. maybe ill read up on how to rebuild it and give it a shot
ikircher is offline
post #5 of 5 Old 08-12-2011, 08:43 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I did an AX-15 rebuild writeup. They're very similar.
Max
Mean Max is offline
Auto wont shift out of park, BRAKE TRANSMISSION SHIFT INTERLOCK MECHANISM seems stuck Rivka TJ Wrangler Technical Forum 19 04-22-2012 08:26 PM
'94 AX-15 grind Urbanmisfit YJ Wrangler Technical Forum 9 02-19-2012 08:06 PM
what could it be? my gears grind if i shift fast. TylerMidthassel YJ Wrangler Technical Forum 14 11-02-2008 04:25 PM
4L Grind... paulthejeeper TJ Wrangler Technical Forum 7 01-07-2008 05:39 PM
Grind in 1st and 2nd shawnsix66 TJ Wrangler Technical Forum 30 06-04-2007 08:45 PM
