She's running HOT!! YJ Overheating. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > She's running HOT!! YJ Overheating.
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 07-07-2011, 08:46 PM   #1
t2timmy
Recently put on a new warn 8000, winch plate dual tube bumper and off road lights all pretty much blocking my grill. She now over heats when stuck in traffic or wheeling. Anything that isn't fast enough to pull air through. It cools and runs fine when on the highway or driving over 30+ mph. I'm sure this has happened to others. I changes the thermostat and added all new fluid and the radiator is around 100k old.. (Jeep has 231K). Anyone have this problem and have some ideas on how to cool.. I was thinking of adding an electric fan? Whattya's say??
Thanks
t2timmy is offline   Reply With Quote Quick reply to this message
Unread 07-07-2011, 09:00 PM   #2
thefewtheproud
Thanks
I've heard of a lot of people in your situation installing an electric fan. Considering that you had no overheating issues until you installed the equiptment that is blocking the grill I'd say that is the problem..Mine was overheating but it was simply a stuck thermostat.
Semper Gumby
thefewtheproud is offline   Reply With Quote Quick reply to this message
Unread 07-07-2011, 09:10 PM   #3
4.7stroker
I would say your fan clutch is not working as it should.
Dwayne
4.7stroker is offline   Reply With Quote Quick reply to this message
Unread 07-07-2011, 09:19 PM   #4
GRYDE001
Dwayne
this, maybe also consider a new alluminum rad. the winch shouldn't matter if you're just sitting still, it would actually matter more if you were above 30 or so and the fac clutch was off
""Leave it stock, it will live longer. Just understand that its never gonna be as fast as a minivan""
GRYDE001 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2011, 10:47 PM   #5
N1vek215
I have a warn 9000 and no overheating here at all. Definitely a problem with with your cooling system.
N1vek215 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2011, 10:59 PM   #6
19OlllllllO41
The new winch and bumper is NOT the issue. There is no way a winch is blocking air flow enough to cause you to overheat. There has to be some other cooling system issue that coincidentally must have began occurring around the same time you installed the winch.
[B]The Present:[/B]
[URL="http://www.jeepforum.com/forum/f22/yj-betty-transformation-1229681/"]'93 YJ[/URL]
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
[B]The Past:[/B]
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2011, 11:10 PM   #7
CreOli
Dwayne
Im with this guy same thing was happening to me and i checked my fan when the jeep was off and spun it and it spun like a upside down bicycle tire so i replaced it and no more overheating ...
CreOli is offline   Reply With Quote Quick reply to this message
Unread 07-08-2011, 03:07 AM   #8
MJMPC
OP can you post a pic of the front of your jeep?
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote Quick reply to this message
Unread 07-08-2011, 05:53 AM   #9
Louie4
I'm leaning towards fan clutch as well. A buddy of mine has a Warn 9000 winch power plant and it covers a great deal of the grill but he doesn't have overheating problems. It gets a little warm on the trail but doesn't overheat.
I'm having the same issue on the trail and now it's gotten a little worse. I needed to replace my fan clutch because the shroud flexed and the fan hit it and tore up both. Unfortunately I have an Autozone fan clutch and when I got my new on it's a total piece of crap. It never locks up even when it's hot.
My plan now is to find an OEM fan clutch and not one of those reman'd ones, they're dump. I'm also going to snag an electric fan from my dad's collection of junk cars and put it in the front for additional cooling on the trail.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 08-18-2011, 09:20 PM   #10
t2timmy
Dammit!! I totally forgot that I posted this thread... (gotta lay off the sauce). I just started another thread on installing the $300+ Flex-a-lite fan I bought to fix the problem, cause I'm too much of a busy stew-nod to remember I posted and peoples actually replied. I could have had my answer and saved myself $300 beans!!! God I feel like an idiot!! ughh I need a beer!
~ Should I go ahead and install the fan - or - fix the stock fan clutch and purge the system of air and re-sell the BRAND NEW fan ~ any opinions welcome.... including "your an idiot"
Thanks ALL!!!
Unread 08-18-2011, 09:34 PM   #11
t2timmy
...... http://www.jeepforum.com/forum/f12/i...92-yj-1254647/
Post to my new link I started tonight... DUH!
Unread 08-18-2011, 09:35 PM   #12
laredojo
stock clutch fan, I personally dont like flex fans. Had one fail in high school, ruined my hood.
formerly member yj89joe
laredojo is offline   Reply With Quote Quick reply to this message
Unread 08-18-2011, 09:39 PM   #13
Xpress
Fan clutch. Replace it then report back.
All about that unibody life.
Xpress is offline   Reply With Quote Quick reply to this message
Unread 08-18-2011, 09:40 PM   #14
laredojo
ha ha. the flex light is an electric fan? not like the old suicide flex fans from the 70's thats why it was 300 bux
Unread 08-18-2011, 09:41 PM   #15
t2timmy
****** ANYONE WANT TO BY A BRANDY-NEW FLEX-A-LITE FAN!!!! *******
- only has 2 tiny holes drilled in the shroud to run the wires through -
