She's running HOT!! YJ Overheating. - Page 2 - JeepForum.com
post #16 of 21 Old 08-18-2011, 08:43 PM
Louie4
Since I last replied to this thread I put an electric Taurus fan in mine. Now my motor runs nice and cool. I think it cost me a total of $60 or so after all was said and done.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #17 of 21 Old 08-18-2011, 08:50 PM Thread Starter
t2timmy
OOPS! So in your opinion should I fix the problem by replacing the clutch fan.... or install the Flex-a-lite?
t2timmy is offline
post #18 of 21 Old 08-18-2011, 08:56 PM
oldtime_ironman
I imagine you could go either way. Since you already got the Flex-a-lite, why not just run that anyhow?
oldtime_ironman is offline
post #19 of 21 Old 08-19-2011, 05:27 AM
Louie4
Depends on you really. I sourced a fan from a junkyard, then got a thermostat, relay and wiring and had to do some trimming on the fan but it was a fun little project.
I would say just get a decent fan clutch and call it done.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #20 of 21 Old 08-19-2011, 05:35 AM
jay-h
Agreed there is something else going on here.
If it were airflow, it would only affect things in marginal situations, that is, situations where you would be almost at the boiling point.
jay-h is offline
post #21 of 21 Old 08-19-2011, 09:03 AM
oldtime_ironman
Agreed. Most likely needs to have a reverse flush to clean the gunk out of the block + radiator. They have a kit for it at Autozone for like $10, I did it to mine and I highly recommend it.
New Water Pump? Overheating when running AC JeffB TJ Wrangler Technical Forum 0 08-10-2010 06:32 PM
Running HOT! and close to overheating Modfatha TJ Wrangler Technical Forum 30 06-14-2007 12:23 PM
Overheating/Running at a higher temperature surfgod04 TJ Wrangler Technical Forum 5 04-20-2007 05:27 PM
Running a bit hot, not overheating tho.... BlewMeAway YJ Wrangler Technical Forum 10 08-05-2006 12:36 PM
She's up again dcafaro YJ Wrangler Technical Forum 0 04-07-2006 10:11 PM
