Shakle Question - JeepForum.com
post #1 of 6 Old 12-29-2001, 06:10 PM Thread Starter
TooHighJeep
Shakle Question
I recently bought a 2 inch Shakle lift for my 93 YJ. When I was trying to install them I ran into some problems. Once I got both the back Shakles off I figured the leaf spings would drop down, however they both snapped up and hit the frame. The back of the Jeep was raised with two jackstands so there was no weight on the wheels. What else do I have to loosen to get the leaf springs to drop down so I can install the new Shakels?
Thanks
TooHighJeep is offline
post #2 of 6 Old 12-29-2001, 09:45 PM
Trucidus Sum
0000000000000000000000
Trucidus Sum is offline
post #3 of 6 Old 12-30-2001, 05:47 PM
9jeep0
9jeep0's Avatar
I had the same problem when I put mine on.All I did was take a crow bar and put it on the leaf spring and clamped it on with a c clamp.Then push down and line up the bolt.
Hope this helps.
RED JEEP CLUB MEMBER #14
2006 TJ 4.0
1987 MJ 4.0
9jeep0 is offline
post #4 of 6 Old 12-31-2001, 01:03 PM
Trucidus Sum
post #5 of 6 Old 01-01-2002, 08:49 AM
9jeep0
9jeep0's Avatar
Trucidus Sum - Not that I need to explain myself to you but I know dang well how many lines a jeep has. The lines are supposed to represent the vent holes. Count those, it's amazing what you will come up with. This is not the place to criticize. It's a place to discuss Jeeps not ascii files. If you don't like it don't look at it. I don't appreciate you your public criticism. If you really feel the urge to say something to people use the private message option.
2006 TJ 4.0
1987 MJ 4.0
9jeep0 is offline
post #6 of 6 Old 01-01-2002, 10:48 AM
blackjeep
when i installed mine i just used a bottle jack and a piece of 4x4 to give me a little extra length. It pushes then right down and then you can raise them slowly so they will slide right into your shackles if its a tight fit, mine where. hope this helps.
95 wrangler 1.5" springover Dana44 front Ford8.8 rear 4.10's 35x12.50 MTR's
blackjeep is offline
Shakle Reverse geevans YJ Wrangler Technical Forum 5 11-20-2008 10:05 PM
Need to cut rear shakle bolts pasinbuy YJ Wrangler Technical Forum 20 06-10-2007 01:57 PM
2 inch shakle lift stillen YJ Wrangler Technical Forum 9 11-12-2006 01:25 PM
shakle reversal racer35 YJ Wrangler Technical Forum 6 10-12-2006 08:58 AM
shakle reversal MugZy_YJ_94 YJ Wrangler Technical Forum 1 04-11-2002 06:42 PM
