shake during acceleration. - JeepForum.com
post #1 of 13 Old 02-13-2013, 09:52 PM Thread Starter
rodgers3
Im getting a shake/shudder during acceleration while in 3rd or 4th at about 30-45 mph.
What should i check first?
rodgers3 is offline
post #2 of 13 Old 02-13-2013, 09:54 PM
b_a_mech
Tie rods and ball joints
BUILT NOT BOUGHT #602 / ZOMBIE RESPONSE TEAM #40 / USN HULL #196
b_a_mech is offline
post #3 of 13 Old 02-13-2013, 10:47 PM
timatoe
timatoe's Avatar
Only during acceleration? Same speed coasting along is fine? Look at the trans mount and u-joints in the drive shaft first, because they're both cheap and you can just look at them to see that they're bad.
timatoe is offline
post #4 of 13 Old 02-14-2013, 01:22 AM
landozer18
engine mount on mine did it at slight slower speeds
landozer18 is offline
post #5 of 13 Old 02-14-2013, 05:36 AM Thread Starter
rodgers3
I think its drive shaft related bbecause i can feel it a little while coasting through 30-45.
It shakes real bad during accel though
rodgers3 is offline
post #6 of 13 Old 02-14-2013, 05:50 AM Thread Starter
rodgers3
Thanks guys got a list of thing to check.
rodgers3 is offline
post #7 of 13 Old 02-14-2013, 06:15 AM
Tarpo
Make sure your hubs are unlocking. I was wheeling the other day, shifted out of 4wd then hit the highway. I noticed a shake at about 50. Then I looked down and realized my posi knob was still out. Slowed down, unlocked it.... The shake went away. Also check if anything is on or wrapped up in your drive shaft.
Tarpo is offline
post #8 of 13 Old 02-14-2013, 05:26 PM Thread Starter
rodgers3
I only feel it on accel. Coasting is fine. Im going to replace the rear ds u-joint. It wiggles a little when in a certain position. Hopefuly this will solve the problem
rodgers3 is offline
post #9 of 13 Old 02-14-2013, 07:53 PM Thread Starter
rodgers3
Any suggestions on u-joints ?
rodgers3 is offline
post #10 of 13 Old 02-14-2013, 07:56 PM
140mower
Spicer is a good name, and I prefer the grease-able ones. Do yourself a favor and replace both at the same time for the piece of mind.
Don
If it wasn't done the hard way, I didn't do it.
140mower is offline
post #11 of 13 Old 02-14-2013, 08:03 PM Thread Starter
rodgers3
Thanks don.
Will do.
rodgers3 is offline
post #12 of 13 Old 02-15-2013, 11:15 AM Thread Starter
rodgers3
Roadblock...
There's two different sized u-joints that the i could use...
And the guy doest know the one i need...help??
rodgers3 is offline
post #13 of 13 Old 02-15-2013, 11:50 AM Thread Starter
rodgers3
3.622 outside lockup?
3.219 outside lockup
I think its 3.219
rodgers3 is offline
