shackles turned inward with new lift - JeepForum.com
post #1 of 46 Old 08-31-2011, 07:37 PM Thread Starter
stratostix
Im in the process of installing a 4 inch lift on my yj. I finished putting the front springs on but this is how far I had to rotate the front shackles inward... is this normal? Advice?
[IMG=http://img268.imageshack.us/img268/9687/2011083119373763.jpg][/IMG]
Uploaded with ImageShack.us
stratostix is offline
post #2 of 46 Old 08-31-2011, 07:49 PM
soonermatt
Make sure the bolts were loose when you lowered it to the ground. You may have locked them tight.
soonermatt is offline
post #3 of 46 Old 08-31-2011, 07:52 PM Thread Starter
stratostix
The car is actually off the ground in this pic. I had to turn it this far inward in order to reach the frame mount with the other end of the leaf spring...
post #4 of 46 Old 08-31-2011, 08:00 PM
soonermatt
And when you lower the jeep it should 'squash' the spring causing the shackles to be more upright.
post #5 of 46 Old 08-31-2011, 08:03 PM Thread Starter
stratostix
Oh ok. Makes sense . Thx.
post #6 of 46 Old 08-31-2011, 11:41 PM
fratis
fratis's Avatar
this is a common problem with 4" and up springs. they just dont make them long enough. they tend to let the shackle sit almost vertical even when the jeeps weight is on the springs.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #7 of 46 Old 08-31-2011, 11:44 PM Thread Starter
stratostix
u mean... the shackle is sitting horizontal right? Either way... do you recommend a new set of shackles? If so what kind?
post #8 of 46 Old 09-01-2011, 12:02 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
The weight of the Jeep on the springs will make the shackle sit vertical. I would get new shackles , I have always used MORE shackles on my Jeep's but there are a few guys on here who make badass shackles you can get front and rear for the price on a pair of MORE .
Send a PM Besrk , or VACJ5 about Their shackles and center tubes for the shackles
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Last edited by Tom95YJ; 09-01-2011 at 02:24 PM. Reason: Got vertical and horizontal mixed up
Tom95YJ is offline
post #9 of 46 Old 09-01-2011, 12:19 AM Thread Starter
stratostix
Originally Posted by Tom95YJ View Post
The weight of the Jeep on the springs will make the shackle sit horizontal. I would get new shackles , I have always used MORE shackles on my Jeep's but there are a few guys on here who make badass shackles you can get front are rear for the price on a pair of MORE .
That's what I thought. It looks like the shackle is passed the point of being pushed out and would instead roll inward against the frame if I put the jeep on the ground... Thx for the info. I'll look into that.
post #10 of 46 Old 09-01-2011, 03:28 AM
Mark05059
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #11 of 46 Old 09-01-2011, 04:08 AM
Tom95YJ
Tom95YJ's Avatar
Originally Posted by Mark05059 View Post
That is a very interesting article you had typed, There is some really helpful information in your post. I hope you didn't get Carpal Tunnel Syndrome from all of that typing, My eyes were sore and my brain was hurting after reading that .
'99 XJ Black Betty
Tom95YJ is offline
post #12 of 46 Old 09-01-2011, 05:20 AM
bogleparsons
man Tom is a hardass, I like
bogleparsons is offline
post #13 of 46 Old 09-01-2011, 10:55 AM
fratis
fratis's Avatar
no i meant what i wrote. the springs are never long enough to allow the shackle to sit at the proper angle when weighted. yes when weighted the shackle will swing forward into the proper direction but in my view never far enough.
thats not going to happen and if it did that would be wrong. around 45* is optimal but never attainable with lift kit springs and factory mounts. they always make the shackle sit closer to vertical then any optimal angle. this is why inversion is so common.
how would new shackles help?
fratis is offline
post #14 of 46 Old 09-01-2011, 12:51 PM
Virjeep
Don't get new shackles to fix your "problem", as it won't. As Fratis said, springs just aren't long enough. We have all gone through this, and it generally isn't a big problem once installed. Get new shackles if you want them, but I don't think it will change the way they sit.
Virjeep is offline
post #15 of 46 Old 09-01-2011, 04:19 PM
ssyj94
Like it's been said new shackles wont do a thing for you except lighten your wallet. Let the weight down on the suspension then post up another picture. A few companies springs are way to short when arched to 4".
My build:
ssyj94 is offline
Anyone run a RC lift with 1/2" lift boomerang shackles and only TC drop? MA88XJDude YJ Wrangler Technical Forum 11 04-11-2010 07:43 PM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
4in suspension lift + 2in shackles + 2in body lift = 35in tires? snou52 YJ Wrangler Technical Forum 24 03-22-2009 06:21 AM
RE 4 inch lift with 1" lift shackles...ok driveline angles? sk80soarus YJ Wrangler Technical Forum 8 12-05-2007 06:05 PM
steering wheel turned after lift install? xjandyj YJ Wrangler Technical Forum 4 09-28-2007 08:10 PM
