shackles - JeepForum.com
post #1 of 3 Old 06-23-2001, 01:50 PM Thread Starter
bonehead99
bonehead99's Avatar
shackles
I bought a pair of shackles but they didn't come with directions. I need to know which end is up? the bar that connects the sides is closer to one end than the other.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 3 Old 06-23-2001, 06:21 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Have the bigger gap toward the spring eyes. This will allow more movement of the spring during suspension action as the shackles will move. To put on the shackles put the jeep on jackstands (under the frame, with the axles hanging free) and then put a floor jack under the axle. You can then use the floor jack to raise or lower the spring eyes into the shackles.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #3 of 3 Old 06-23-2001, 10:54 PM Thread Starter
bonehead99
bonehead99's Avatar
thanks for the info...Also will I have to replace the bushings?
All about shackles Brandon_YJ YJ Wrangler Technical Forum 98 02-03-2014 08:35 AM
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 01:35 PM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 06:39 AM
shackles bignateb YJ Wrangler Technical Forum 13 03-22-2009 12:30 PM
MORE shackles standnstillfast YJ Wrangler Technical Forum 8 11-18-2005 02:28 PM
