Shackles - JeepForum.com
post #1 of 4 Old 06-23-2002, 04:28 PM Thread Starter
jeepinarkansas
1982 CJ8
Shackles
Should there be any movement in the shackle when the jeep is in motion? Like when it hits a bump it should be allowed to flex, right? I think that I tightened up those bolts too tight with an impact wrench when installing my lift. Is that possible?
Thanks for the advice on this hard to explain problem.
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #2 of 4 Old 06-24-2002, 08:10 AM
Dan's YJ
Ya, you can over tighten them. They do need to move a little. If you do, you'll prob. start eating your bushings. hth
1994 Bronco HD
Warn 8000
2"lift, 32x12.50
Locked
Dan's YJ is offline
post #3 of 4 Old 06-24-2002, 09:00 AM
Jeep Man
Check your owners manual. There is a torque spec.
I've felt the hate rise up in me, kneel down and clear the stone of leaves, I wander over where you can't see, inside my shell, I wait and bleed... Goodbye!
Jeep Man is offline
post #4 of 4 Old 06-26-2002, 03:30 AM
Paulwpetrea
Paulwpetrea's Avatar
If they are aftermarket shackles, you should have loc-nuts on the shackle bolts. You should torque these down to around 30 foot pounds.
Believe me, you will have a MUCH better ride, if you have them loose enough to flex.
Paul
Paulwpetrea is offline
All about shackles Brandon_YJ YJ Wrangler Technical Forum 98 02-03-2014 08:35 AM
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 01:35 PM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 06:39 AM
shackles bignateb YJ Wrangler Technical Forum 13 03-22-2009 12:30 PM
MORE shackles standnstillfast YJ Wrangler Technical Forum 8 11-18-2005 02:28 PM
