Shackles???????? - JeepForum.com
post #1 of 5 Old 07-17-2001, 08:18 PM Thread Starter
Tony & his 91' YJ
Shackles????????
What's goin on there my jeepin family?? I just bought one and a quarter inch shackles. I have a 2.5" susp lift but it's rubbin a litle bit and I do want a little more height out of my YJ. Was this a poor descion? I thought it was better than a body lift but now I'm havin second thoughts. Any experience with shacles and a lift?? Please respond.
/____\
{OlllllO}
Tony B.
1991 Jeep Wrangler YJ
2.5 liter Herculined, 2.5 ProComp Suspension lift, 1.4 shackle lift, New Gibson Exhaust,31 Pro Comp Mud Terrain, Olympic Grill guard, Olympic Brush guard, smittybuilt nerf bars with step, Hella 550
91 YJ
/____\
{OlllllO}
Tony & his 91' YJ is offline
post #2 of 5 Old 07-17-2001, 08:26 PM
bigjeep39
bigjeep39's Avatar
Shackles are easy, lift by the frame to take the load of the springs, then put the shackles on, (do front first) then lower the Jeep and wrench on the shackle bolts, if you do it when it is in their air you will bind the bushing, the idea of the shackle is to move back and forth,. Good Luck
1998 TJ
Slow steady project.
bigjeep39 is offline
post #3 of 5 Old 07-17-2001, 11:05 PM Thread Starter
Tony & his 91' YJ
Thanks BigJeep. Is it safe to run bigger shackles?
Tony B.
91 YJ
/____\
{OlllllO}
post #4 of 5 Old 07-18-2001, 12:19 AM
shea324@aol.com
I think that a shackle lift is a better choice than a body lift. I have experience with both and the only problem with the shackle lift is that your track bars will push on your shackles a little. but you can always just take these out alltogether and avoid the hassle. The simple body lift can become very complicated. Between Shifting problems, Freeing up the steering column and that annoying space under the body, a body lift is just not worth it. Learn from my mistakes, thats my $0.02
90' YJ Four Banger, 2" Lift, 31" Tires, Many Mods to come
shea324@aol.com is offline
post #5 of 5 Old 07-18-2001, 09:52 AM Thread Starter
Tony & his 91' YJ
Thanks for you .02 shea324. It made more sense to me as well.
Tony B.
91 YJ
/____\
{OlllllO}
All about shackles Brandon_YJ YJ Wrangler Technical Forum 98 02-03-2014 08:35 AM
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 01:35 PM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 06:39 AM
shackles bignateb YJ Wrangler Technical Forum 13 03-22-2009 12:30 PM
MORE shackles standnstillfast YJ Wrangler Technical Forum 8 11-18-2005 02:28 PM
