shackles for 2.5 RC lift - JeepForum.com
post #1 of 7 Old 08-19-2011, 03:24 PM Thread Starter
sbs1794
I am about to get a 2.5 inch RC lift for my 89 YJ and I was wondering what would be the best option for shackles. I dont want a stock height shackle but nothing with a crazy lift either. also what are people's experiences with the total lift gained from the 2.5 kit as I have read some people saw 4-5 inches in lift
sbs1794 is offline
post #2 of 7 Old 08-19-2011, 04:13 PM
nzpete
I ended up with about 4 inches total, but that was due to worn out original springs. They have settled slightly, but overall I ended up with 2.5 inches from a stock height. If you're going to lift it, you really should remove the rear track bar. This isn't in the instructions, but it makes a world of difference. If you're going to increase your lift even further by adding a shackle lift, I would not only remove the rear, but the front track bar as well.
At the end of the day, however, I would reconsider the RC lift and go with OME.
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
post #3 of 7 Old 08-19-2011, 04:17 PM Thread Starter
sbs1794
tight budget, would love the OME though, what shackles did you use?
sbs1794 is offline
post #4 of 7 Old 08-19-2011, 04:29 PM
Jim1611
Jim1611's Avatar
Have you thought about putting a set of boomerang shackles on? Also I'd say that with a 2.5" lift you'd be fine with 1" over stock length on the shackles. Too much change in shackle length can great affect the way your YJ will handle since the longer the shackle the more it changes the caster angle. If you want/need more lift then buy it in the aftermarket springs.
Here's a full set of stock length shackles I shipped out this week. They are made from 3/8" thick material and have the greasable bolts.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is online now
post #5 of 7 Old 08-19-2011, 05:33 PM
giggityjeeper
a 2" lift shackle for when your RC crap lift sags so bad...... LOL.....
some boom shackles would be good 1/2 lift maybe
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #6 of 7 Old 08-20-2011, 06:22 AM
nzpete
I only went 5/8 of an inch on the shackles and they are the boomerang type. While all Jeeps are different, read up on, and be prepared to troubleshoot the vibes that you'll most likely experience after the RC install.
I absolutely hate the transfer case drop as a means of resolving vibe issues as it defeats the purpose of lifting a Jeep.
I ended up with an SYE, a double cardan Woods rear driveshaft, (a front Woods DS just because they treated me so well), and a 1 inch motor mount lift.
I found that removing both front and rear track bars freed up the suspension and made my Jeep ride much, much better. I've left the sway bar attached, but plan on a quick disconnect soon.
Good luck.
nzpete is offline
post #7 of 7 Old 08-20-2011, 10:25 AM
giggityjeeper
you will do good to get the 2.5 from RC springs, the reason ppl get 4-5 is like someone said, the ones you have are so bad...... If I go by those standards my OME 3.5" springs gave me 7" of lift over what I had, but since my originals were inverted I figure it was about 3.5" Like it said.....
Once the RC 'settles' as people call it, you will be back to about stock height maybe an inch higher
2.5 , lift , rough country , shackle , shackles
Anyone run a RC lift with 1/2" lift boomerang shackles and only TC drop? MA88XJDude YJ Wrangler Technical Forum 11 04-11-2010 07:43 PM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
4in suspension lift + 2in shackles + 2in body lift = 35in tires? snou52 YJ Wrangler Technical Forum 24 03-22-2009 06:21 AM
i have a lift with shackles, can I put a 1" body lift as well? yjJeff YJ Wrangler Technical Forum 8 02-09-2009 10:54 AM
RE 4 inch lift with 1" lift shackles...ok driveline angles? sk80soarus YJ Wrangler Technical Forum 8 12-05-2007 06:05 PM
