shackles - Page 2 - JeepForum.com
post #16 of 35 Old 08-10-2011, 05:39 PM Thread Starter
Jarred2
it seems like everyone has the same thing to say about the track bars. looks like thats my next project. with the track bar, does that also include the steering damper?
Jarred2 is offline
post #17 of 35 Old 08-10-2011, 05:55 PM
imstillatwork
Have a friend help, k?
imstillatwork is offline
post #18 of 35 Old 08-10-2011, 05:59 PM Thread Starter
Jarred2
never mind. i got it. gonna be ordering some quick disconnects. any brand you recommend?
Jarred2 is offline
post #19 of 35 Old 08-10-2011, 06:04 PM
oldtime_ironman
Nope, the track bars are completely separate from the steering damper. They're basically just a couple pieces of heavy pipe bolted thru each end.
oldtime_ironman is offline
post #20 of 35 Old 08-10-2011, 06:06 PM Thread Starter
Jarred2
thanks. i had a blonde moment and figured that out on my own. lmao. but are there any brand of quick disc's that you guys recommend?
Jarred2 is offline
post #21 of 35 Old 08-10-2011, 06:39 PM
imstillatwork
Nope. take the stupid thing off, sway bar also. Rear track bar also. Take them off. Then come back and thank us.
post #22 of 35 Old 08-10-2011, 06:41 PM Thread Starter
Jarred2
wouldnt i still want the sway bars at least for the street?
Jarred2 is offline
post #23 of 35 Old 08-10-2011, 06:45 PM
imstillatwork
you might, most people don't. I have OME springs and don't run a sway bar, it's totally stable. These aren't race cars. Your RC springs do all the heavy work of keeping things in place. The trac bar and sway bars full time job is to restrict movement of the suspension.
At very minimum, remove the trac bars, and disconnect the sway bar & zip tie it up against the frame. drive a round a bit and see what you think. Do you do any off road at all? you'll never put the sway bar back on. I daily mine and will never put it back.
post #24 of 35 Old 08-10-2011, 06:45 PM
imstillatwork
You most definitely do NOT need the trac bars though. There is no downside to removing them!
post #25 of 35 Old 08-10-2011, 07:17 PM
TheNewbie
Just unbolt one end and tie it up with some wire and drive like that for a week. You'll probably find that you nvever really noticed any difference in handling, but it rode a bit better.
If this is the case then just unbolt the other side and throw the whole thing in the dumpster. If you didn't like it then order or build a disco.
I took all of mine off when I installed the lift and never looked back.
No, you need to keep that.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #26 of 35 Old 08-10-2011, 07:23 PM Thread Starter
Jarred2
alright. i will take ur guys advice when the jeep and i get reaquainted with each other.
Jarred2 is offline
post #27 of 35 Old 08-10-2011, 07:40 PM
VACJ5
Let me know if you are interested in a set of boomerang shackles... I have cut a few sets for some fellow jeep owners on the forum.
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #28 of 35 Old 08-11-2011, 12:05 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I had ran my YJ with out the Swaybar , or Trac-bars F&R for years it was my DD also. If you want to keep a swaybar the best swaybar disco's are the ones made by JKS they run around $135 and are made alot better than others
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #29 of 35 Old 08-11-2011, 12:27 PM Thread Starter
Jarred2
i just met this guy today whom i noticed had the jks sway bar disco's and he said they dont hold up very well and the pins tend to break and stuff. is this true.?
Jarred2 is offline
post #30 of 35 Old 08-11-2011, 02:30 PM
oldtime_ironman
Actually I just removed my sway bar completely about an hour ago. I'm very pleased with the results. It's a lot less harsh and I can feel the articulation over bumps and holes. This means that I'm getting more traction. I already had the track bars out. It does handle somewhat "softer" but not enough to be an issue. I'll have to practice a bit driving with the new setup.
teraflex revolver shackles vs boomerang 5/8 more shackles jpringles YJ Wrangler Technical Forum 21 12-23-2010 02:35 PM
Which shackles? AnonymousD YJ Wrangler Technical Forum 5 09-29-2010 06:33 AM
To add shackles or not to add shackles that is the question! 1997_Sport YJ Wrangler Technical Forum 16 09-30-2009 07:39 AM
shackles nick94yj YJ Wrangler Technical Forum 2 05-23-2007 08:12 PM
Shackles and SRS sorry YJ Wrangler Technical Forum 4 01-13-2005 12:28 AM
