shackle and t-case - JeepForum.com
post #1 of 4 Old 02-05-2002, 06:58 PM Thread Starter
usclimber1
shackle and t-case
if i get about a 2inch shackel lift for my 95yj with a 2inch body, will i need to do anything with my transfercase, or anything else?
thanks
usclimber1 is offline
post #2 of 4 Old 02-05-2002, 07:24 PM
Tailgummer
Body lift will have no affect on driveline angles etc. but will be alot of work to install. 2" shackle lift will affect the driveline angles and pinion angles of both axles. Probably not enough to be a problem but also will not give you the 2" of lift you may be expecting. Typically a 2" shackle lift pushes your spring down and inch and your body up and inch. The best way is to pick up a 3-4" lift kit and install it. Far fewer problems.
Good luck
Chuck
Good Luck
Chuck
'91 YJ, 4.0L 5sp, Atlas II, RE SOA + 2"BDS, 35" Explorer Xterrains, ARB's & 4.56 gears, WARN 9000i
WWW.4x4xnorthwest.com
Tailgummer is offline
post #3 of 4 Old 02-05-2002, 07:45 PM Thread Starter
usclimber1
thanks bud, what do you mean by 3/4 lift(shackel, sus, body?) what kind of things would i have to do to the 3/4
thanks chuck,
ambers
post #4 of 4 Old 02-05-2002, 09:54 PM
RodeoRob
RodeoRob's Avatar
a 3-4" lift kit like Tailgunner is talking about would replace your existing springs with lift springs. This is a far better way of doing things in the long run. No longer shackles, no add-a-leafs, no body lift. these kits also typically include new shocks, trackbar relocation, brake line extensions, and transfer case drop.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
T-case Shifter Bracket upgrade w/ T-case drop and body lift 04<TJ>renegade TJ Wrangler Technical Forum 1 04-05-2009 06:08 PM
Bent rear diff and cracked transfer case, what diffs and case will bolt into my 87 YJ hillside250 YJ Wrangler Technical Forum 9 01-08-2009 01:45 AM
transfer case issues 91 auto to 88 standard case... input shaft?? dream911tommy YJ Wrangler Technical Forum 1 12-22-2008 12:23 PM
Shackle Reversal and M.O.R.E. Shackle help mcgann454 YJ Wrangler Technical Forum 5 12-11-2007 08:00 AM
transfer case shift linkage problems after t-case drop heezy101 TJ Wrangler Technical Forum 5 08-29-2006 07:02 AM
