shackle reversal - Page 2 - JeepForum.com
post #16 of 17 Old 04-03-2002, 09:45 PM
RodeoRob
RodeoRob's Avatar
I hardly proved myself wrong.
No, i don't think you did. I think I see your point... but i'm still hanging onto my orignal statement.
what about this... hear me out... a certain force acts vertically, moving the axle up, this is your bump, call it F1. Then there is a force require to move the shackle on its axis (with a flat spring, this force would be horizontal), call it F2.
From this we can have two scenerios right...
#1: F1 is greater than F2, in which case the axle follows the path of least resistance, moving forward (away from the fixed point) pushing the shackle.
#2: F2 is greater, in which case the spring would go from flat to inverted, moving the axle towards the back of the jeep on its axis (fixed point C), and the shackle would be sucked in towards the axle as a result.
I believe me and Mr Mopar are arguing scenerio #1 happens while you are saying scenerio #2 happens. which actually does? i dunno, but i'm still guessing #1.
This is exactly why Jeeps come from the factory with the shackles in the front.
well, what about other vehicles that come with 'flat' leaf springs from the factory? wagoneers and FSJs, they are noterious for having flat springs and they come with shackles reversed right? what about K5 blazers, i know they have shackle reversal and their stock springs are inverted. that would go against your arguement.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #17 of 17 Old 04-04-2002, 09:39 AM
4wheeler4CJ
4wheeler4CJ's Avatar
The geometry works, no question, and shackles in the front work better with flat springs. Period. There's no way to discount it, no matter how other vehicles are configured.
Shackle reversal can only work on Jeeps with arched lift springs. Even then, I remember reading some negs on the setup, it's not a cut-and-dry good thing to do.
But, then, what is?
4wheeler4CJ is offline
Shackle Reversal kwikshift YJ Wrangler Technical Forum 8 10-15-2011 05:57 AM
Shackle Reversal VACJ5 YJ Wrangler Technical Forum 0 05-18-2009 07:01 PM
shackle reversal WYRENUT YJ Wrangler Technical Forum 10 04-09-2008 05:12 PM
Need help with shackle reversal loborojo338 YJ Wrangler Technical Forum 2 03-03-2008 12:14 PM
shackle reversal Dutchboy YJ Wrangler Technical Forum 14 08-30-2004 04:41 AM
