Shackle question - JeepForum.com
post #1 of 3 Old 05-27-2001, 12:41 AM Thread Starter
Keymaster
Keymaster's Avatar
Shackle question
Okay, I think I've narrowed down my decision for a lift. I want to thank all who replied to my earlier message on lift ideas. I think I wanna keep things simple. I have a 91 YJ with a 6 cyl, 5-speed and 31 in. tires. I was thinking of just going with a shackle lift and maybe going with 32 x 11.5 inch tires. I have 15 x 8 inch wheels, so will that size tire fit? Also, will just a shackle lift be enough for 32's? Does anyone have a problem with this setup? I know it doesn't sound like much of a modification, but I just got this Jeep (it's my first) and I'm still babying it. Maybe later I'll get hardcore. Right now I just want to get it looking good for the summer. Thanks again for your help.
1997 F-150
2000 Ford Explorer
Looking for a YJ!
Keymaster is offline
post #2 of 3 Old 05-27-2001, 09:01 PM
Jeepaholic
Shackle lifts are a bit sketchy...if you get too much lift, you'll screw up the caster/camber and your steering will suffer because of it. Your Jeep will gain a mind of it's own and respond to every little rut and dip in the road. It's a bit annoying.
I would say do NOT use a shackle that more than 2" longer than stock. You might be ok at that level...remember this only nets you 1" of lift.
The one inch of lift may help you fit 32's in so you can "look good for the summer" but don't plan on wheeling it. You'll send your tires into your fenders the minute you flex them out. I had a 2.5" spring lift and 2" body lift with 32's at one point in my Jeeping career...they barely tucked under my fenders without rubbing too bad.
Al Bsharah
<< Get your own on-line storefront at no cost to you!
Jeepaholic is offline
post #3 of 3 Old 05-27-2001, 11:06 PM Thread Starter
Keymaster
Keymaster's Avatar
Don't worry....won't be doing any hardcore off-roading. The only place I'll off-road will be in the Outer Banks in the sand. I think rubbing won't be a problem. The previous owner rounded out the fenders because I guess the 31's were rubbing when he put them on.
1997 F-150
2000 Ford Explorer
Looking for a YJ!
Yet another shackle question Rohdawg YJ Wrangler Technical Forum 12 09-08-2009 01:39 PM
shackle question mudsling YJ Wrangler Technical Forum 9 06-01-2009 12:33 PM
Shackle Question??? IPB YJ Wrangler Technical Forum 14 04-30-2007 09:21 AM
Shackle Question Brudmike7 YJ Wrangler Technical Forum 2 12-08-2004 10:13 AM
Shackle Question w/BDS 19OlllllllO41 YJ Wrangler Technical Forum 7 05-23-2003 03:56 PM
