shackle lift - JeepForum.com
post #1 of 11 Old 09-18-2001, 08:02 AM Thread Starter
Atropine
Atropine's Avatar
shackle lift
Im the proud owner of a 93 YJ and I have the parts for a 2in shackle lift, is there any special things I should worry about before atempting to lift it? any pro's/con's? thanks in advance
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #2 of 11 Old 09-18-2001, 09:15 PM
ezgoing
ezgoing's Avatar
I just put a 1 1/4" shackle lift on my 92 yj which was fairly simple. The only thing you may have trouble with is lining up the shackles. I ended up using an old axle shaft to get them in place. Plus I found out the hard way that the gas tank has to be dropped down or moved forwards in order to get the bolts on the rear shackles. However you shouldn't have any othr problems-driveline, brakes etc. Other than that I haven't noticed much difference in the way it drives or handles. Plus every inch counts!
Hope this helps you.
'92 YJ Sahara
1 1/4" shackle lift for now soon to be some sort of lift
31" Bridgestone Dueller A/Ts on AR-767 wheels
'67 Ford Galaxie 500 (passes everything but the gas station)
"What do you mean I can't make it, watch me!" = oops
ezgoing is offline
post #3 of 11 Old 09-19-2001, 04:14 AM
bonehead99
bonehead99's Avatar
I installed 2in shackles on the front of my 94yj which was very easy. The rear I had someone do for me cuz of the bolts. I later learned you should be able to remove the outside half of the bushing allowing you to pull them out at a angle.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #4 of 11 Old 09-19-2001, 09:18 AM Thread Starter
Atropine
Atropine's Avatar
I appreciate all the help!
93' YJ
00' TJ
02' KJ
04' Dodge Ram
Atropine is offline
post #5 of 11 Old 09-20-2001, 02:02 PM
cobra54
Bonehead99 is right. You don't need to drop the gas tank. Just pull out the outside half of the spring bushing and you will be able to get the bolt out. I did it on a
1 1/2" shackle lift on my 93 YJ.
93 Red YJ 2.5L
94 Red F-150 X Cab 5.0L
01 Black Cobra 4.6L DOHC
02 ZX3 Focus 2.0L DOHC
cobra54 is offline
post #6 of 11 Old 09-20-2001, 06:26 PM
ezgoing
ezgoing's Avatar
Man I always end up doing and learning things the hard way!!! One would think I would look at things closer. Oh well, its all good, have fun!
'92 YJ Sahara
ezgoing is offline
post #7 of 11 Old 09-22-2001, 12:58 PM
I-4
I-4's Avatar
does this change your steering geometry at all?does it need to be re-alligned after you put longer shackles on?i'm wanting to get rid of the cheesy stamped steel crap that comes on a stock jeep.just wanting 1 1/2 to 2 inch lift(for now)
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
post #8 of 11 Old 09-22-2001, 04:36 PM
ezgoing
ezgoing's Avatar
No, it doesn't change anything in the steering or else in the drivetrain.
'92 YJ Sahara
ezgoing is offline
post #9 of 11 Old 09-24-2001, 08:08 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I currently am running a 4" lift and was considering the boomerang shackles .. anyone have anything good or bad to say about them?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #10 of 11 Old 09-24-2001, 08:53 PM
bigblueyj
naekid i heard nothing but good things about the boomerang shackles
bigblueyj is offline
post #11 of 11 Old 09-25-2001, 10:45 AM
Newfie
I'm running the greaseable ProComp 'boomerangs' front and rear. http://home.thezone.net/~95jeepyj They are a rear only application according to ProComp, but I flipped them to use as an anti-kickback (same as the M.O.R.E. boomerang shackles) and they are working well. Went with these as I saw several rigs, that had extended shackles, push the shackle up to the frame and bend/break lift springs. HTH
No officer, that wasn't an accident. I did that on purpose...
Newfie is offline
1inch shackle lift after 4in lift...bad idea? Nate M YJ Wrangler Technical Forum 12 01-05-2008 12:17 PM
3.5 suspension lift w/2"shackle lift ? badweather YJ Wrangler Technical Forum 5 12-17-2005 10:41 PM
Cheapest Lift/Shackle/body lift combo to fit 33s on a YJ davekear YJ Wrangler Technical Forum 2 07-24-2005 12:52 PM
Torn, shackle reversal lift or spring lift? YJBlues YJ Wrangler Technical Forum 2 04-23-2005 12:16 PM
shackle lift Meister_jeep YJ Wrangler Technical Forum 6 09-09-2002 06:41 PM
