Shackle Lift - JeepForum.com
post #1 of 7 Old 10-08-2012, 04:42 PM Thread Starter
vinny147
Shackle Lift
So I wanna do a 1" shackle lift from BESRK. As seen here:
http://www.ebay.com/itm/JEEP-YJ-BOOM...item35bfc79923
Since it is only a 1" lift it will not throw off my angles to much right?
and
Dont I need grease able bolts? Where can I get them for this?
Btw I wont be installing these till next summer, I'm building a Christmas list and I will be installing a SYE at the same time.
vinny147 is offline
post #2 of 7 Old 10-08-2012, 04:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You don't necessarily need greasable bolts. A 1" lift should be nice with 4" springs.
Luck Favours The Prepared
Anticanman is offline
post #3 of 7 Old 10-08-2012, 04:52 PM
Mark05059
Since it is only a 1" lift it will not throw off my angles to much right? no
and
Dont I need grease able bolts? no but you can get some if you wish
Where can I get them for this? regular bolts (grade 8) can be found at local hardware stores. Greaseable bolts can be had from quadratec.com
hope the above helps
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 7 Old 10-08-2012, 04:56 PM Thread Starter
vinny147
Ok that answers my question. Do you all think the grease able bolts are worth the money?
vinny147 is offline
post #5 of 7 Old 10-08-2012, 05:04 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I have them and don't think they're worth the money
post #6 of 7 Old 10-08-2012, 10:12 PM
Taguilar
I have them and I think they are worth it. Ive neglected them in the past and would hear pops when I would brake hard. I knew that I hadnt greased my bolts in a long time and the bushings were dry. After I greased them up, the noise when braking hard went away. I would assume that this noise would happen when off roading too but I never took it out with the bushings dry. If you want your leaf spring bushings to stay quiet and last a long time, buy the greasable bolts.
Taguilar is offline
post #7 of 7 Old 10-08-2012, 10:16 PM
fratis
fratis's Avatar
90% of the time they are misused and useless. if you want to make sure your bushings are working properly just pop them apart and grease them. grade 5 bolts are fine as well.
-insert meaningless out-of-place political diatribe-
fratis is offline
