Shackle bolt size?? - JeepForum.com
post #1 of 5 Old 06-21-2010, 09:10 AM Thread Starter
mysterymachine
Shackle bolt size??
I will soon be installing a Rubicon Express 4" lift into my 93 yj. I am going to replace the bushings at the top of the shackle where they bolt into the frame since they are 17 years old and disappearing(rotting) away. I plan on putting new bolts in. What size should the bolts be?
mysterymachine is offline
post #2 of 5 Old 06-21-2010, 09:16 AM
samsonitesamson
1/2" x 4" grade 8
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline
post #3 of 5 Old 06-21-2010, 09:20 AM
ZeroGravity
The actual measurement is from the shoulder to the end of the threads, so make sure you get the correct length fasteners.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #4 of 5 Old 06-21-2010, 07:14 PM Thread Starter
mysterymachine
Thank you both for the quick replies.
post #5 of 5 Old 06-21-2010, 07:28 PM
samsonitesamson
Yeah, just one quick side note. I just did this when I put new shackles on my Jeep, the 1/2"x4" is the right size with stock shackles, which I am assuming you are using, but I had to get 1/2" x 5" because my new shackles are 3/8" thick, and I used washers on each size with a lock washer.
Bolt size(Dana 30 Diff. Cover Bolt) Cobra001 TJ Wrangler Technical Forum 8 10-05-2009 05:22 PM
bolt to bolt shackle distance shu2kill YJ Wrangler Technical Forum 3 08-14-2009 04:08 PM
Big Bolt Problem, need to know trans to motor bolt size FAST!!!!! antec YJ Wrangler Technical Forum 5 06-05-2009 11:39 AM
What size bolt in front of frame to bolt hook on? 01blackws6 YJ Wrangler Technical Forum 4 01-09-2009 03:53 PM
confirm bolt size please. rear upper CA Bolt ? TJ_with_Tusks TJ Wrangler Technical Forum 2 10-09-2008 02:06 PM
