Shackle area frame replacement - JeepForum.com
post #1 of 9 Old 11-24-2013, 01:46 PM Thread Starter
mv7fd
Anyone install that pre frabbed section of frame where the rear shackle mounts my section on frame is getting a little rotten and am looking at buying that and want to know if it's worth buying and if you have to cut out the frame or just cut the bad section out and slip the pre made piece on
mv7fd is offline
post #2 of 9 Old 11-24-2013, 08:23 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Not on my Jeep, but I have done it both ways depending on the amount of damaged area there is.
Joe Dillard is offline
post #3 of 9 Old 11-24-2013, 08:51 PM
NHfireLJ
NHfireLJ's Avatar
I bought the pre made, cause mine frame was completely toast... but fabbing your own, wouldn't be hard
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #4 of 9 Old 11-24-2013, 11:40 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I installed on of the rear frame kits on my brothers YJ a few years back It fit great and it was holding up fine for the few years he had that YJ before he sold it.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #5 of 9 Old 11-25-2013, 04:32 AM Thread Starter
mv7fd
Do you just slide it up on the existing good part of the frame or butt it up to the frame where you cut it and weld it
mv7fd is offline
post #6 of 9 Old 11-25-2013, 04:43 AM
NHfireLJ
NHfireLJ's Avatar
2 options. Cut out all the old rotted sections of the frame, lower and side portions, and then match the replacement piece back in.. (look at my pic, the inboard is shorter than the outboard....)
Or just cut the frame all the way across leaving the top and use the whole new replacement piece.
Also use a "fish eye" on butt sections (look it up), Strengthens the butt weld area. I didn't and I had no problems but as stated my inboard and outboard were staggered
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #7 of 9 Old 11-25-2013, 04:50 AM
CJ51973
CJ51973's Avatar
I used the prefabbed and a new crossmember. I cut out so there was a little over lap per instructions so no butt welds. I have beat it on the trail all year without issue.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #8 of 9 Old 11-25-2013, 07:33 AM
firefighter315
I used the pre-fab pieces from ART. It saved a lot of time and the price was right. I replaced the passenger side rear and the fuel skid front cross member. The frame end was simple - just mark dimensions and remove what you need to, leaving the top (or making your own new top piece). The cross member was a little more detailed, but still easy. Lots of measuring and marking to make sure everything is where it needs to be.
Sorry, it seems I didn't get a photo of the new end before primer/paint....
There are more pics in my build thread if you want to see any more.
My YJ Build Thread
firefighter315 is offline
post #9 of 9 Old 11-25-2013, 09:40 AM
Tom95YJ
Tom95YJ's Avatar
I cut out the bad areas and painted it with POR15 then installed the full length cap welded it and coated with more por15
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
