Several slider & factory soft top questions - JeepForum.com
post #1 of 1 Old 10-02-2011, 05:23 AM Thread Starter
cdlongjr
1974 J-Series Truck
My driverís side upper slider has the front section of glass broken and the knob to pull it is missing. Can a glass shop replace the glass? Where can I find a replacement knob?
Is the larger handle supposed to hold the glass stationary when you open it? If yes, mine doesn't. What's do I need to repair/replace?
What type and size bolts/screws do I need to install the half door side posts? These are the rails that go up the sides of the windshield where I'm pointing.
Thanks
CD aka "Papaw"
87 Wrangler Laredo
cdlongjr is offline
factory soft top questions orangez TJ Wrangler Technical Forum 10 03-17-2008 09:04 PM
Upper Slider w/ Soft Top tmwoodall TJ Wrangler Technical Forum 1 12-08-2006 09:14 PM
Soft top slider hardware LOCKED UP YJ Wrangler Technical Forum 0 10-28-2006 07:04 PM
factory hard top + bestop upper door slider kit? j-ro TJ Wrangler Technical Forum 5 09-22-2003 07:52 AM
