serpentine belt - JeepForum.com
post #1 of 27 Old 08-30-2008, 05:17 PM Thread Starter
twokids
1983 CJ7
serpentine belt
How do you replace the belt?
I thought 1 of the pullies would be spring loaded.
twokids is offline
post #2 of 27 Old 08-30-2008, 05:30 PM
The Rat
Under the PS pump is a tensioner bolt. All you gotta do is loosen that up and it loosens the belt.
Mine was seized so I had to remove the PS pump completely...but it was ok because my PS pump was shot as well.
OH WAIT. WHAT?
The Rat is offline
post #3 of 27 Old 08-30-2008, 05:36 PM
Alfons
All the belt adjustment bolts are located on the power steering pump assembly. The very top bolt must be loosened, then on the back of the assembly, you'll see two bolts sitting in holes that are slotted - both of these need to be loosened. Now on the front again, look just below the steering pump pulley and you'll see (or feel) a bolt there, this also must be loosened. Finally, on the side, at the bottom of the assembly, you'll see a bolt head - this is the adjustment bolt, and is about 3 or 4 inches long. Have a look at this and see if the threads are clean and spray it with a bunch of penetrating oil - now you're ready to start turning. All the bolts I described have a 1/2" head and I use a 1/2" wrench or gear wrench for all but the adjustment bolt, and for that I use a 13 mm socket, just to give me a bit of slop to make it easier to put the socket onto a rusted bolt head. Turn the adjustment bolt counter clockwise to loosen, but watch how hard it is to turn, you may need to go back and forth a few times to get past any accumulated rust, otherwise you're likely to break the bolt - add oil as you turn it back and forth a few times.
You need to remove the air box completely to get to the adjustment bolt and the bottom bolt on the front (this bottom bolt is a lock bolt for the adjuster.
When you're done, don't forget to tighten ALL the bolts again, otherwise the pump can get pulled askew.
Alfons is offline
post #4 of 27 Old 09-02-2008, 10:15 PM
93TRJeep
i'm planning to do this in the morning as i know its goina be a B****
Chris
93TRJeep is offline
post #5 of 27 Old 09-02-2008, 10:25 PM
No_Return
Before you dive in... not all YJ Jeeps have the adjustment in the P/S pump.
If you have A/C your belt tensioner may be on the Alternator instead of the P/S pump.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
post #6 of 27 Old 04-25-2009, 12:20 PM
jetchey321
anyone have any pictures of this.....mines a '94 no A/C 2.5
jetchey321 is offline
post #7 of 27 Old 04-25-2009, 02:06 PM
Shags78
I just replaced my belt before I hit some trails this past Tuesday and used a Gatorback belt. The instructions above by Alfons are very good. I actually just unbolted my PS pump and went that route because I didn't even see the adjustment bolt. All said it took me around 10-15 minutes to do this. One of the easier jobs on a Jeep like changing fluids and plugs. I know I have a belt diagram on my 95 with AC right under the hood on the fan shroud. I don't know if a 94's belt routing is any different but I'll post a pic regardless.
Shags78 is offline
post #8 of 27 Old 04-25-2009, 02:51 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Several photos. The various fasteners are difficult to get a clear shot of. This is a shot from the front, directly above the PS pulley and the belt, looking down. You can see the tensioner bolt threads horizontally across the middle of the photo. The bolt head you see must be loosened to allow the "slide" on the tensioner bolt to move.
Here is a shot of the tensioner from under the Jeep, looking up and forwards. The black hose to left is the low pressure line from the PS pump, you can see the lower part of the curve of the PS pump pulley in front of the tensioner bolt.
This next photo is a closeup of the tensioner bolt threads, and the slide thingey, you can see just a wee bit of the lockbolt head above, "behind," and to the left of the slide as this photo is taken from under the Jeep looking forwards just as in the last photo in this reply sequence.
Finally, some specs on the tensioner bolt itself.
I seem to recall that you also have to loosen the bolts holding in the PS pump to allow the pivoting movement that allows either loosening or tightening to take place. Once new belt is on, you can make them all finger tight, then tighten the tensioner bolt to the desired tension, tighten down the lock bolt, then final torque the other bolts holding your PS pump to its mounting points.
Give me a few moments while I go back outside and put it all back together......
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #9 of 27 Old 04-25-2009, 03:32 PM
jetchey321
Thanks for the help! Gonna try and tackle that job tomorrow!
post #10 of 27 Old 04-25-2009, 05:22 PM
timatoe
timatoe's Avatar
It would help if you list which engine you're refering to. The serp on the 4.2 is both adjusted and routed different than the 4.0.
timatoe is offline
post #11 of 27 Old 04-25-2009, 09:48 PM
Opihi59
Opihi59's Avatar
timatoe--we're currently answering the question posed by jetchey321 25 April 09 who has a 94 with a 4.0 The OP of this thread posted up the original question in Aug '08, and it was "thread resurrected." Thanks for chipping in though.....I don't have a clue about things on the 4.2 yet.
Opihi59 is offline
post #12 of 27 Old 04-26-2009, 10:39 AM
timatoe
timatoe's Avatar
I usually catch the old thread thing and didn't even see the second question......
timatoe is offline
post #13 of 27 Old 04-26-2009, 11:19 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
It got me also Tim. I was wondering why a guy with a CJ7 was asking the question. Actually jetchey321 has a 2.5L which is adjusted from the power steering pump.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #14 of 27 Old 04-26-2009, 12:14 PM
Opihi59
Opihi59's Avatar
So Jetchey321--you've got the cheering section rooting for you on this job even if we are outta synch. Tell us how it all turns out for you.
Opihi59 is offline
post #15 of 27 Old 04-26-2009, 03:06 PM
greenerob
2014 JK Wrangler
Sorry to hijack this a bit, but I have the same motor and I need to change my belt. I think that I found the tensioner bolt but when I loosen it it does nothing.
Does anyone have pictures that aren't so close up as the ones a couple of posts ago?
Thanks
Rob
1995 Jeep Wrangler Rio Grande 4in RC Lift 33" Tires with 73,000 miles. Auto Trans
greenerob is offline
87 YJ serpentine belt 258 WITHOUT AC jeepguy85 YJ Wrangler Technical Forum 16 11-06-2012 03:09 PM
Serpentine Belt SwearingYeti YJ Wrangler Technical Forum 1 01-04-2006 09:00 PM
Serpentine Belt WAMPAROO TJ Wrangler Technical Forum 2 08-22-2004 07:00 AM
Serpentine Belt Hero TJ Wrangler Technical Forum 2 06-04-2003 08:10 PM
Serpentine belt cptn_mrgn78 TJ Wrangler Technical Forum 5 04-05-2003 05:18 PM
