Serious power loss - JeepForum.com
post #1 of 15 Old 08-31-2007, 03:16 AM Thread Starter
shinigami
Serious power loss
after hitting a few bumps on the road, i have lost almost all power .
going up hill, with a starting speed of 50, i end up at 30 or 25.
it seems to require more rpm's to maintain a constant speed and wont go above 50
there isnt much unusual noise either and shifts through all gears fine.
will this be a serious rebuild to the transmission or might it be something that i might be able to do with basic tools? i had it rebuilt at the beginning of the year and am still a little wallet sore from it.
Originally Posted by jmathis3 View Post
lots of hair pulling, tool throwing, beer drinking, swearing, and eventualy it will start. haha good luck.
I LOL'd
I.Y.A.A.Y.A.S.
shinigami is offline
post #2 of 15 Old 08-31-2007, 04:33 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Honestly it sounds like your cat just took a dump. It clogged the exaust and you lost your high end power.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 15 Old 08-31-2007, 05:20 AM
EABiker
x2 on the cat, the bump jarred loose the internal honeycomb and it has blocked your exhaust. You may only need to replace the cat if none of it has found its way back into the muffler. Now is a good time to upgrade to a hi-flow version!
EABiker is offline
post #4 of 15 Old 08-31-2007, 06:09 AM
richmond1273
there is also the possibility of a crack in your exhaust manifold. check just above the collector where the pipes start to combine. it doesn't take much of a crack to lose some power. here is where it seems to a common spot.
1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears
3" Rough Country suspension 33x12.50 Mastercraft MT
2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears
richmond1273 is offline
post #5 of 15 Old 08-31-2007, 10:02 AM Thread Starter
shinigami
how can i see if it is my cat with out removing it?
i could swear it was my trans but that sounds like a better problem than a rebuild
I LOL'd
I.Y.A.A.Y.A.S.
post #6 of 15 Old 08-31-2007, 10:04 AM
rustywrangler
Get under your rig and bang a rubber mallet or your fist on the cat. If it rattles it is the culprit. It may also be so clogged that you will not be able to tell unless you take it out. Another option is to disconnect your exaust at the manifold and see how it runs. I know, loud but you would be able to tell if there was restriction still or not.
post #7 of 15 Old 08-31-2007, 10:33 AM Thread Starter
shinigami
taped it and no rattle.
no cracks along the manifold.
gona try unbolting it later.
any other ideas?
I LOL'd
I.Y.A.A.Y.A.S.
post #8 of 15 Old 08-31-2007, 09:41 PM Thread Starter
shinigami
gonna remove the cat tonite, if it is dead where should i go to get a good one?
I LOL'd
I.Y.A.A.Y.A.S.
post #9 of 15 Old 08-31-2007, 10:07 PM
Burnerman
Burnerman's Avatar
I got my cat from these guys.http://www.1aauto.com/1A/CatalyticCo...CD00069/378849
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #10 of 15 Old 08-31-2007, 10:38 PM
SWAMPED
Junior Member
can a cracked exhaust manifold cause powerloss such as engine surges and idling a little rough??
SWAMPED is offline
post #11 of 15 Old 09-01-2007, 05:40 AM
rustywrangler
YES
post #12 of 15 Old 09-01-2007, 10:46 AM Thread Starter
shinigami
do i need to weld a cat on or can i clamp and use jb weld?
I LOL'd
I.Y.A.A.Y.A.S.
post #13 of 15 Old 09-01-2007, 12:06 PM
rustywrangler
My entire exaust was muffler clamped togeather for a few months. NO JB WELD!!!!!!!!!!
Should not be a problem. Only reason I welded it now is because I can weld now
post #14 of 15 Old 09-01-2007, 02:18 PM Thread Starter
shinigami
y no jb weld?
its rated for 600 degres.
I LOL'd
I.Y.A.A.Y.A.S.
post #15 of 15 Old 09-01-2007, 03:29 PM Thread Starter
shinigami
how hot does it get? 250 degrees?
I LOL'd
I.Y.A.A.Y.A.S.
Loss of power ImRaptor YJ Wrangler Technical Forum 30 11-12-2006 06:10 PM
Loss of Power AHighFiveToLife YJ Wrangler Technical Forum 2 03-21-2006 10:54 AM
Loss of power??? JimDandy TJ Wrangler Technical Forum 4 05-01-2004 10:14 PM
'95 YJ 4.0 loss of power RedBug YJ Wrangler Technical Forum 21 04-20-2004 08:23 AM
Power Loss ! bigjeep310 YJ Wrangler Technical Forum 12 03-28-2004 03:49 AM
