Sequential VS regular multiport fuel injection - JeepForum.com
post #1 of 4 Old 10-28-2011, 07:35 PM Thread Starter
m0jo
So I just managed to figure out my Jeep originally came with a 95 I6 and was swapped to a 91 I4 and wow is it confusing when you get parts for a 95 based on your VIN (which says 95 I4) which inst your VIN cause somebody swapped your windshield frame so your VINs don't match and you think somebody swapped your vehicle with somebody else's and didn't realize it (my registration is the chassis VIN).
Anyway, confusion aside, from what I can tell the only real difference (correct me if I'm wrong) between the 95 and 91 engines is the distributor and that the 95 has sequential multi port injection instead of simultaneous multi port inject like the 91 has. Is it a worthwhile endeavour to convert the 91 to sequential or is it a time waster? What would have to be swapped out? Is there any performance or fuel consumption differences?
Thanks for any help guys.
m0jo is offline
post #2 of 4 Old 10-28-2011, 09:40 PM
tbburg
It doesn't make that much difference. Engine management controls improved over the years, but HP and efficiency didn't change that much. Not sure of the Wrangler numbers, but for an XJ, between '87 and 2001, the HP jumped from 177 up to a whopping 196(the biggest improvement involved the TB, intake and head, not the electronics).
Kind of confused about your post, but if you Jeep is a '95, and has a '91 motor in it, odds are it still has the '95 FI setup. If the chassis is a '91, and has a '95 block, it's probably using the '91 electronics.(Usually, when we swap the 4.0s between chassis, the simple method is to strip the accessories from the block and use the controls and sensors from the vehicle)
The injector sequence is set by the computer. The injectors themselves are identical. To swap from the early to the late system involves swapping the computer, harness and sensors.
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
My other car is also a Jeep,.. and so is the other one,.. and that one too. How many do you own before it's "a herd" ?
tbburg is offline
post #3 of 4 Old 10-28-2011, 10:26 PM Thread Starter
m0jo
The chassis and tub are '95 and originally had a 4.0L I6 in it, one of the PO's put a 91 2.5L I4 in it along with a new windshield frame, hood and fenders, the computer must have been swapped because it went from a 6 cylinder to a 4. What year computer is in it I do not know for sure, but I would assume it came with the engine, so that means 91 unless its REALLY been frankensteined.
On the note of computers, How would one find out if the sensors between 91 and 95 are different? I have changed the O2 and noticed that afterwards it has run rather rich and I'm just now considering that that may have caused it
m0jo is offline
post #4 of 4 Old 10-29-2011, 09:48 AM
Cobra Jeep
All 91 and newer 4 and 6 cyl engine are sequencial injection. A few parts changed here and there over the years, but they are all basicly the same engine management system. The only big change was in 96-97 when they changed to OBD-2.
So your 91 4 cyl is already sequencial injection.
The 90 and older were carb on the 6 cyl, and tbi injection on the 4 cyl.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
fuel , injection
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection kit for 4.2l -87 Mickesweden YJ Wrangler Technical Forum 6 11-21-2007 07:19 PM
Fuel Injection help funJ YJ Wrangler Technical Forum 2 09-26-2005 04:29 PM
4.2 Fuel Injection Kit? TommyT YJ Wrangler Technical Forum 4 05-06-2003 04:47 PM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 01:02 PM
