Security suggestions? - JeepForum.com
post #1 of 47 Old 04-07-2006, 09:00 AM Thread Starter
Nosh686
Well its time.....I am finally bringing my Jeep down to college (from Maryland to Alabama) I cant wait I am so excited to finally have my baby! The only thing that I was thinking about was...... there are no locks on my car anywhere...... so I was woundering if anyone had any suggestions for me where I can get come locks to install or just anything that will help....one idea that I had was just to lock the so called trunk area and just keep everything in there….anything will help. Thanks a lot!
Nosh686 is offline
post #2 of 47 Old 04-07-2006, 09:12 AM
bamato
bamato's Avatar
Start by NOT locking your doors, if people want in, they will fina way in. Also, buy a tuffy security console for 225$. Keep all your valuables in there, including your stereo. It fita a lot of stuff. And last, wire up a killswitch. You'll be set
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #3 of 47 Old 04-07-2006, 09:18 AM
Fixins13
You can get a piece of sheet metal that sits on top of the fenders behind the rear seat and is a "trunk," if you lock your tailgate. If you've got a press brake or a torch and long workbench, you could make one yourself for a lot less. Do you have full steel doors? If not, no sense in locking them anyway since anyone can get into them with an exacto knife. I've bought a couple sets of steel doors and it's not terribly expensive to take the locks out to a locksmith and have them re-keys to your ignition key. The Tuffy Security console is a great item. It locks your stereo away from people who'd take it and has a good amount of space for other stuff. I made a litte adapter plate and put my CB in the space where my stereo used to be. No one is stealing CB's. Unless I'm running the hard top and full doors, I leave my Jeep unlocked. Easier to replace some junk from your car that a top. This is a trick a convertible owner taught me.
I love sleep. My life has the tendency to fall apart when I'm awake, you know?
Ernest Hemingway
Fixins13 is offline
post #4 of 47 Old 04-07-2006, 10:29 AM
TellyDSP
Poland and PPV!!!!
it's pretty much been covered. The Instratrunk served me well in Baltimore City, so I think it would be fine in AL. Are you running a hard or soft top?
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #5 of 47 Old 04-07-2006, 11:29 AM
drexelsteve
i removed my glove box and put in a tuffy security vault. extremely high quality and that's where i keep my faceplate, cell, or wallet. No chance of gettin in there unless they go at it with a sledge, and that'll definitely set of the alarm. I've also got cheesy hoodlock and i use a long-u masterlock around the clutch and brake pedal levers as an antitheft. keep a couple burned cd's and a pack of smokes in the console, they're disposable.
13 Rubi
drexelsteve is offline
post #6 of 47 Old 04-07-2006, 11:43 AM
BudmanV6
One problem with not locking the doors is that they are that much easier to steal.
1992 Wrangler Sahara, 4.0L, 5spd, RE 4.5 XD lift, Fox remote reservoir shox, 33x12.5-15 BFGoodrich All-Terrains, 15x8 black rock crawlers, JK rubicon pneumatic swaybar, JKS quick disconnect track bar, Teraflex HD SYE, Tom Woods driveshaft, Ford 8.8 w/ 4.10 gears and arb locker, D30 w/ 4.11 gears and arb locker, York 210R OBA w/ Kilby mount, Dynomax Ultra Flow SS muffler, Alterstart 165A alternator, TJ flares, and Poison Spyder rocker knockers.
BudmanV6 is offline
post #7 of 47 Old 04-07-2006, 12:08 PM
TellyDSP
Poland and PPV!!!!
if they want them, they'll slit your windows and unlock the door. best thing for that is to keep the hinge nut on. The nut's a PITA if you want to take your doors off though.
-Craig-
95 Rio Grande
07 Ram 1500
TellyDSP is offline
post #8 of 47 Old 04-07-2006, 05:10 PM
92 Green YJ
92 Green YJ's Avatar
when i was at college i left the hardtop on with full steel doors and a viper alarm system. never had a problem
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #9 of 47 Old 04-07-2006, 05:29 PM
Flashfoto
Hidden ignition kill switch & hood lock. Keep everything else, unlocked & empty of valuables. Total cost, about $23.00. :-)
Flashfoto is offline
post #10 of 47 Old 04-07-2006, 06:01 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
yea just don't keep valuables in your jeep.... that seems easy enough. take the face off the cd player.... there, nothing else is worth anything to a crook.....
if you're worried about the whole jeep getting stolen just unplug the 3 wire connector at the gas tank on the driver's side when you leave the jeep... without a fuel pump you can't drive or you coudl wire up a kill switch somewhere.... that would cost you less than $5
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #11 of 47 Old 04-07-2006, 07:05 PM
ImRaptor
Have to be careful with not locking your doors. Some insurance companies will refuse to cover any theft that they deem as result of not having the doors locked. At least if they are locked, and your window gets slit and stuff stolen, you'll be covered on everything.
I'm going the route of a 2 way paging alarm with internal radar sensor myself.
Your mom is using you to get to me. How sad is that....
for me.
ImRaptor is offline
post #12 of 47 Old 04-07-2006, 07:35 PM
72cj5er
72cj5er's Avatar
1972 CJ5
He didnt cover the year of his Jeep, I think he said it has no locks. I just sold a set of 89 doors and they didnt have a lock in them at all, not even a place for one. I wonder if the insurance would have a problem with that? I guess some Jeeps in the late 80s didnt have locks on the doors cause Ive seen many like the ones I had
72 CJ5 Renegade
86 MJ Pickup W/Tilt bed
94 YJ Wrangler
04 LJ Unlimited Wrangler
never far from a good trail
Growing old is mandatory; growing up is optional!!
72cj5er is offline
post #13 of 47 Old 04-07-2006, 07:39 PM
Fixins13
Most stuff in the inside of your car is NOT covered by auto insurance. Anything that's not bolted to it, typically isn't covered. In any case, I'd like to see an insurance company who can prove my doors were unlocked at the time of a theft. Most of these folks ain't exactly CSI Miami. Mostly they sit in front of computer.
Insurance Co: Were your doors locked at the time of the loss?
Me: Yes.
Insurance Co.: When the vehicle was recovered they were unlocked.
Me: Imagine that. You think maybe the bad people unlocked them while they were stealing my Jeep?
Ernest Hemingway
Fixins13 is offline
post #14 of 47 Old 04-07-2006, 08:48 PM
Taco88yj
another question...
is there a YJ center conslule? can someone link me a part number or does the TJ one bolt in?
Taco88yj is offline
post #15 of 47 Old 04-07-2006, 09:21 PM
toates89
1989 XJ Cherokee
is there a certain fuse that you could take out so the car wouldnt start?
toates89 is offline
Security? phillzii TJ Wrangler Technical Forum 5 10-26-2007 02:06 PM
Security Box ozjeep TJ Wrangler Technical Forum 5 10-27-2005 09:43 AM
security key paul olllllllo TJ Wrangler Technical Forum 2 10-16-2005 11:04 AM
Security suggestions? Opettaja TJ Wrangler Technical Forum 1 01-10-2005 05:46 AM
Security ckster TJ Wrangler Technical Forum 11 01-05-2004 08:15 PM
