Seat risers- interchangable? - JeepForum.com
post #1 of 5 Old 07-29-2010, 02:10 PM Thread Starter
Destr0
OK so my drivers side seat riser is cracked and rusty, and the bolts are pretty rusty. I found a passenger one on CraigsList for $10. Is there any difference between the two (other than the passenger is a flip forward seat, having a flip on the drivers side seems handy)?
For $10 I think that would be worth it, as long as it will fit. I know the flip forward handle will be on the wrong side, but that can't be too hard to flip or fabricate to the other side. I think it will be easier than trying to get my existing seat frame out without destroying it and then repairing it.
My question is, will it work and has anyone added a passenger riser to the drivers side?
Cheers!
~K
Destr0 is offline
post #2 of 5 Old 07-29-2010, 02:19 PM
clush
i would think that one side is higher to accommodate the drivetrain if I am remembering correctly. if so, the left side of the riser is higher on the passenger seat while the right side is higher on the driver seat. you know, the hump that runs down the middle of the tub where the transmission and driveshaft, etc run. Seems like I remember seeign that last time I took my seats out.
clush is offline
post #3 of 5 Old 07-29-2010, 02:23 PM
Roadyy
Go look at the way they mount and the slider mechanism and you will see the difference between the pass side and driver side just in that fashion. THe passsenger side is also one piece as you know for fold and tumble where the driver side is 2 piece. Also the inside mount is lower than the outside so if you reverse them it would be turning the slide mech to the back of the seat.
Roadyy is offline
post #4 of 5 Old 07-29-2010, 03:29 PM
Area.3.Fiftyone
The passenger side is different and they are not interchangeable.
Some YJ's came with flip driver's and passenger seats and those are interchangeable with stationary seats but not side to side.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #5 of 5 Old 07-29-2010, 03:36 PM Thread Starter
Destr0
Thanks guys! I honestly can say I have not looked at the passenger seat on my YJ yet. It works and is rust free. I have spent a lot of time under my Heep trying to get the stupid riser off without luck. I am afraid I am going to have to cut it off and think I will just try and get a new one rather than fix the one that is rusted, cracked and going to get cut out.
I have found a drivers side flip riser for the same $10 (but on this one I gotta pay shipping too) so it is a non-issue.
Destr0 is offline
87 flip up seat risers and seat exchange PASKS YJ Wrangler Technical Forum 3 09-04-2009 09:34 AM
Direct bolt in Seat Swap, 87-89 seat risers different than 90-95 hillside250 YJ Wrangler Technical Forum 8 04-03-2009 02:33 PM
Seat Risers? vfrpilot TJ Wrangler Technical Forum 5 06-11-2008 10:24 PM
TJ Seat Risers Hesher420 TJ Wrangler Technical Forum 11 01-24-2008 09:04 AM
Seat risers...all the same? gbeltran YJ Wrangler Technical Forum 0 11-27-2004 05:31 PM
