Quantcast Seat Removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Seat Removal
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 09-25-2007, 07:51 AM   #1
Fish4it
Seat Removal
Alrighty, I can get to the back two torx head bolts but not the front, any ideas on how to move the seat farther back to access them? 92 Wrangler
Thanks
81 CJ-7 3.0 lift, Weber, HEI, 33*11.50 BFG Mud Terrains on Richard Cepek DC-1, Warn front, rear bumpers and rock sliders. Warn 8000 winch.
92 Wrangler, 2.5 lift, Mickey Thompson Classics with 32*11.50 ATR's Rock Crusher F&R Bumpers.
08 Wrangler JK,HardTop, automatic, 2 inch Skyjacker lift and 33/12.50/17 BFG AT's
Fish4it is offline   Reply With Quote
Old 09-25-2007, 08:40 AM   #2
E_ROCK
I guess I am a little confused. My seats had two that were accessed from the cab and two that you had to remove from under the jeep. So in other words two were more like studs that attached to the seat and the other two were standard bolts.
Garage Monkey, Wheeling Junkie
www.rockfrogs.org
E_ROCK is offline   Reply With Quote
Old 09-25-2007, 09:42 AM   #3
versoel
2009 JK Wrangler
im not sure. i didnt have any problems removing my seats. they came out with a little help of the impact gun.
versoel is offline   Reply With Quote
Old 09-25-2007, 10:20 AM   #4
goatchze
That's how mine is as well. Thanks to massive oil leaks in the past, the nuts were not rusted at all! LOL.
Was true for both the passenger and drivers seat if I recall.
"Hey, hold my beer and watch this...I can make that"
goatchze is offline   Reply With Quote
Old 09-25-2007, 10:37 AM   #5
Fish4it
I should clarify, they are the bolt holding the seat to the frame.
Thanks
Old 09-25-2007, 10:42 AM   #6
DevinB
After you take off two of the bolts, you should be able to move the seat forward or backward on the frame like you would if you were adjusting your seat while sitting in it. That should give you access to the other two bolts.
DevinB is offline   Reply With Quote
Old 09-25-2007, 11:00 AM   #7
Fish4it
Thanks, I'll give that a try.
Old 09-25-2007, 11:54 AM   #8
timatoe
Jello Puddin'
timatoe's Avatar
I pulled my seats out with the risers attached and then pulled the riser off the slider, then slider off the seat. Replaced both seats this way in under half an hour.
Originally Posted by jbolty View Post
... never underestimate the idiocy of Nancy Pelosi...
timatoe is offline   Reply With Quote
Glock Forum
