Quantcast Seat removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Seat removal
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 05-20-2007, 05:30 PM   #1
05LjNj
Seat removal
I'm trying to get out my front seats and the bolts are just rusted and being a pita.. is it worth it to just cut them and grab just some general replacements? they are rusted so i wouldnt want to use them anyway...
05LjNj is offline   Reply With Quote
Old 05-20-2007, 05:31 PM   #2
05LjNj
im trying to take out the interior to roll in a herc kit..
Old 05-20-2007, 07:00 PM   #3
Exparrot
If they won't come out with PB, heat, BFH and/or a combination of all of the above, you may be able to drill them out and re-tap a new hole for your replacement hardware when you put the new ones in.
Try PB Blaster first. Soak 'em once or twice a day thoroughly for a week, and try it again later.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline   Reply With Quote
Old 05-20-2007, 07:40 PM   #4
05LjNj
so, being that i broke two bolts lol.. just drill them out completely and then what.. put a bolt all the way through and cap it with a washer and nut?
Old 05-20-2007, 07:48 PM   #5
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
If you do not have the ability to tap the holes, then just go ahead and drill all the way thru. You can slide a new bolt down the hole and add a nut to the other side. Don't drill the entire lenght of the bolt, use one size bigger so that when you reach the bottom of the threads on the nut the rest will just fall off. Saves you some time and the bit life.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 05-20-2007, 08:22 PM   #6
05LjNj
so drill a hole like three quarters of the way through the stuck nut with a one size bigger drill bit? then use the same size oem nut and it will push through?
what kind of bit do you use for this? how long do the last
Old 05-20-2007, 08:24 PM   #7
Ares
Whatever you do...don't go down to local hardware store and just buy some bolts and stick the sucker back together. AT LEAST get grade 5 bolts. Last thing you want to do is put isshy hardware onto one of the most critical restrait systems in your vechile.
- Cameron
Axle Information Thread
Oil Filter Study
Ares is offline   Reply With Quote
Old 05-20-2007, 08:33 PM   #8
Grape Ape
I'm tired
Grape Ape's Avatar
Just use a regular drill bit.
What he meant by using a larger drill bit is like in the picture A shows the drill bit bigger than the bolt you only have to drill through to the bottom of the nut and the remaining bolt will just fall off. If drilled with a smaller drill bit like in B you have to drill further down to get through the entire bolt.
Then just get a bolt nuts washers and lock washers for putting the seats back in after you line the tub. Ensure you use a higher grade bolt and lock washers. Don't want the bolt to break or come undone when you really want the seat to stay in place.
The Final Salute
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things...
...the people you meet and the books you read. Charles E. Jones
Grape Ape is offline   Reply With Quote
Old 05-20-2007, 09:08 PM   #9
rustywrangler
Great visual Grape. That is exactly what I ment. Definatly go with good hardware. Tractor supply is the cheapest I have found for grade 5 and 8 bolts. Spend the extra 5 cents and get grade 8 stuff.
Glock Forum
