Seat belt question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Seat belt question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 09-21-2008, 02:37 PM   #1
someguy17
2000 FSJ Cherokee
Seat belt question
My drivers side female end seatbelt is completely non working now and I just wanted to confirm that this seat belt from quadratec fits and works
http://www.quadratec.com/products/24247_40X_PG.htm
looking at the picture the part that bolts to the floor doesn't look angled like the oem buckle so would I have to get this to make it work?
http://www.quadratec.com/products/24247_900.htm
Thanks for the help
,J
1992 Black YJ and couldn't be more happy.
someguy17 is offline   Reply With Quote
Unread 09-21-2008, 03:47 PM   #2
timatoe
The part that bolts to the floor is covered by the plastic sleeve in that pic. You don't need that extension, unless you've got a tall console or something making it difficult to get to.
timatoe is offline   Reply With Quote
Unread 09-21-2008, 04:57 PM   #3
someguy17
2000 FSJ Cherokee
thanks a lot
Unread 09-22-2008, 09:54 AM   #4
Matt The Hammer
I just bought the same seatbelt from Summit for $59. You need that bracket. Here's why
Look at the angle the new female end bolts. It is designed to bolt into a vertical surface so that the female end is also vertical.
The issue is that the Wrangler female bolt hole is horizontal. The OEM end has a bend in it so that the end sticks up. The new one does not.
You need to buy the angle piece from quadratec. Note, that is just ONE angle in that price.
Then you need to bolt the new female end into the angle bracket.
I literally just did this a few days ago.
2013 JKU
1995 YJ
Matt The Hammer is offline   Reply With Quote
Unread 09-22-2008, 10:13 AM   #5
jbolty
ISO 9001 Compliant
jbolty's Avatar
Or, get a piece of 1" x 1/4" bar stock, bend it and drill two holes in it.
I had to fix a rust hole in my floor and as part of that project I put in a 2 x 2 x 1/4 backing plate for the seat belt bolts for extra strength.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 09-22-2008, 10:16 AM   #6
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
YOU DO NOT need any extra brackets when you buy that kit. What the pic does not show you is that it comes with a 90* bracket to go vertical. I have that belt on my drivers side right now.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Unread 09-22-2008, 10:23 AM   #7
TempVAJeep
I just went to the junk yard & got one out of an old buick $5 The strap was a little short, but I got up the nerve to take the "buckle" appart & swap out the strap & while I was at it, replaced the "GM" button w/ the orange one I had
TempVAJeep is offline   Reply With Quote
Unread 09-22-2008, 12:51 PM   #8
Matt The Hammer
Maybe that bracket is the $10 increase?
The one I bought from Summit lacked it. I was just going to bolt it to the floor and bend the plastic housing so that it was similar to the OEM design. But after measuring, the female end would have been lower than the seat height.
I have a center console. Factory one, but a console nontheless.
2013 JKU
1995 YJ
