seafoam - JeepForum.com
post #1 of 38 Old 12-06-2006, 12:25 PM Thread Starter
jaysky
seafoam
i read a few posts about seafoam and was planning on using it in my 87 4.2 Auto.
how do i use it.
do i put it in the fuel tank?
i read somewhere that u put it in the intake. do they mean pour it down the carb and if so while the engine is running or not.
also i saw someone said to put it in the brake booster. how do you do that. they arnt talking about the master cyl right.
thanks
jaysky is offline
post #2 of 38 Old 12-06-2006, 01:03 PM
mp3coupe
mp3coupe's Avatar
how do i use it.
thanks
Some pour it slowly into the intake, others remove the vacuum hose from the brake booster and allow the engine vacuum to suck it in. You can pour some into the tank. I prefer Chevron Techtron cleaning additive that you add to the gas. Seafoam is a good cleaner for internals but as a gas treatment Techtron all the way
mp3coupe is offline
post #3 of 38 Old 12-06-2006, 02:07 PM
bobbert350
bobbert350's Avatar
u can put it in the fuel if u want...u can put it in a vac hose from break booster..or u can pour it threw the carb that will work also just make sure u dont let the engine stall out and pour slow
bobbert350 is offline
post #4 of 38 Old 12-06-2006, 04:14 PM
Swampwalker3
1987 YJ Wrangler
People put it in the oil as well.
Also, not starting after the seafoam is a side affect. Spark plugs seem to hate sea foam and expect a lot of smoke.
Swampwalker3 is offline
post #5 of 38 Old 12-06-2006, 04:17 PM
bobbert350
bobbert350's Avatar
if u put it in the oil only drive about 50 miles b4 u change it i heard it breaks down the oil i may be wrong...but i think the easiest way is to pur it in threw the carb but pour slow and dont let it stall just keep reving it from under the hood it will take a bit then turn off and wait like 5 mins then have fun watching it smoke
post #6 of 38 Old 12-06-2006, 07:37 PM
Marauderk
Slowly pour it into the carb till must of it is gone then pour it alittle faster till the motor stalls don't rev it up just let it stall then let it sit 5 to ten min and make sure your outside and start it up. If you have alot of carbon buildup it will smoke so much you will think the thing is on fire.
89 YJ Islander Yellow, 258 Clifford intake holly carb MSD 6
Smittybilt flat fenders, Dick Cepek 3.5 in lift, Warn 8000I
2007 Rescue Green 2d Rubicon 6 speed soft top
Rubicon express 3.5 superflex system,35 in interco truxs mt's, skidrow skid plates, Killby muffler plate
Marauderk is offline
post #7 of 38 Old 12-07-2006, 02:38 AM
Dmrennells
when i worked at Champion Auto, this is the way we did it: pour it in the carb slowly, then drownd the engine, let it sit for bout 10 min. while you are waiting, pour the rest of the can in the tank. when you start it back up, it will smoke like hell, but thats a good thing. throw away the empty can and you are done.
I didn't get stuck; I just experienced a temporary lack of momentum.
Roads? Where we're going, we don't need 'roads'.
Dmrennells is offline
post #8 of 38 Old 12-07-2006, 11:32 AM
JeepTransformer
So is it the same for a fuel injection?? Pour it in the throttle body till it stalls??? ALso, how hard is it to get it started after you drown it???
Also, it doesnt hurt the CATS does it??
2nd GEN CUMMINS, Manual, Stock
brraaap
JeepTransformer is offline
post #9 of 38 Old 12-07-2006, 11:36 AM
bobbert350
bobbert350's Avatar
i would just pour it threw the break booser its really easy way since i dont know about the throttle body.... personally i dont let mine stall out itself i pour most of it slow then il put my hand over the carb and cut it out
post #10 of 38 Old 12-07-2006, 11:44 AM
JeepTransformer
Ya where can i pick this stuff up?? ALso, Its the brake booster the hose that connects to my air box... The one that runs down towards the driver side??? (not to the valve cover)
brraaap
post #11 of 38 Old 12-07-2006, 11:52 AM
bobbert350
bobbert350's Avatar
u can get it at advanced autoparts, pepboys, autozone alot of places carry it its in a white bottle with red writing...only reason i say this is it makes it easier to know what ur looking for
post #12 of 38 Old 12-07-2006, 12:13 PM
-=DeanstuD=-
-=DeanstuD=-'s Avatar
Here is a pic to help you find it in the store. The smaller can is about $6 at Autozone, I hate to imagine what the lager one costs.
For fuel injection just use a vacuum hose and suck it out of the can...
Dean E. Chandler
'87 4.2 5spd Waggy springs 31/2 mismatch tires 8274
'97 TJ Sport 4.0 32RH D44 4.10 ARB York XD9000i Long Arm SYE
Cornelus, Oregon
-=DeanstuD=- is offline
post #13 of 38 Old 12-07-2006, 12:14 PM
98formulaLS1
98formulaLS1's Avatar
the BEST way to use it is to pour it into the brake booster. pouring it into the intake doesnt do much because it immediatly mixes with the fuel. But if you pour it in the brake booster hose, then it immediately cleans the intake and heads.
1994 XJ---1994 Honda Civic---2000 Honda CBR600 F4
98formulaLS1 is offline
post #14 of 38 Old 12-07-2006, 01:16 PM
Jeeples
Jeeples's Avatar
You can thank me later
http://video.google.com/videoplay?docid=6187290865726229173&q=Seafoam&hl=en
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is online now
post #15 of 38 Old 12-07-2006, 04:19 PM
ElvisV04290
ElvisV04290's Avatar
this looks sweet, think I'll get some for my old '90 tomorrow, and the video is a big help Jeeples.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
seafoam! bmx_hb_guy YJ Wrangler Technical Forum 0 05-11-2008 08:01 PM
seafoam? bmx_hb_guy YJ Wrangler Technical Forum 4 05-07-2008 07:40 PM
Seafoam chriscisme YJ Wrangler Technical Forum 24 05-05-2008 08:35 PM
Seafoam ????'s 01amberfirewv TJ Wrangler Technical Forum 5 09-01-2006 05:00 PM
seafoam markbento TJ Wrangler Technical Forum 15 08-17-2006 12:00 AM
