Scuba tank? - JeepForum.com
post #1 of 11 Old 07-12-2007, 07:17 PM Thread Starter
Gif38
Scuba tank?
hey guys, I know a lot of people use various tanks and compressors to inflate on the trail. I have a 3000 psi scuba tank and want to use it for this purpose.
Anyone use one? how many tires can I fill off of this?
Thanks, Jeremy
Gif38 is offline
post #2 of 11 Old 07-12-2007, 07:22 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
you can definatly use it...
the amount of tires you can fill will depend on the size of the scuba tank and the pressure you fill it to.
if you had onboard air you could fill an unlimited number of tires.
if you actually had it filled @ a scuba place to 3000 psi and could somehow use it with a regulator and air chuck you could fill more tires than i could imagine you would ever need to at a given time.
if you filled it to 150psi or so (normal pressure for an air tank) i can't see you filling more than a couple 33's or so....
i'd probably pass on it myself.....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 11 Old 07-12-2007, 07:36 PM Thread Starter
Gif38
cool. its a 80cu in @ 3000psi. I have a fill station I used for paintball that has a bleed off. i was thinking of running an air line/chuck off of it. would a reg be necessary? i can controll the air flow by the valve knob.
Thanks, Jeremy
Gif38 is offline
post #4 of 11 Old 07-12-2007, 08:48 PM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
i'd put a regulator on it. you don't wanna infalte your tires too quickly, and it would be nice to also see how much pressure is left in the tank. anyone know how much used scuba tanks go for nowadays?
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #5 of 11 Old 07-12-2007, 08:54 PM Thread Starter
Gif38
got mine for $60 on ebay. my company does hydrotesting so i had it serviced for nothing.
Fills are $5.
Thanks, Jeremy
Gif38 is offline
post #6 of 11 Old 07-16-2007, 06:16 PM
Bubba Ray
You will have to fill that tank yourself and not a dive shop after a while. They must be inspected every 5 years. I have used my tanks for just this purpose with an inflater valve purchased at a local dive shop. You will need a reg. unless you are good with the valve because they can flow a lot of air very fast!
Bubba Ray is offline
post #7 of 11 Old 07-16-2007, 06:25 PM Thread Starter
Gif38
My company does the hydros. what reg do i need?
Thanks, Jeremy
Gif38 is offline
post #8 of 11 Old 07-17-2007, 05:38 AM
divenutt
Don't do it.
Scuba tanks are very strong. Valves, however, aren't. They are made of brass and chrome plated. It doesn't take much to damage or worse break the valve.
You don't want a loaded tank taking off inside your jump should the valve get loose.
Jeff
Master Scuba Diver Trainer
Dive Shop Manager
Texas Hunting Rig - 89 YJ/CJ Hardtop with Safari Racks, 4.2 L w/ Weber 34, 31x10.5 Pro Comp Extreme Mud Terrains on Black Pro Comp rims, sound bar, seating for 8, 4 receiver hitches, 4 KC Daylighters, and 2 cupholders. Rancho 9000 shocks with in-cab remote switch.
divenutt is offline
post #9 of 11 Old 07-17-2007, 07:39 AM
Maree2_99
What Jeff said. A 3000 psi tank in a car accident is basically a bomb that might explode.
On the other hand if you had a used SCUBA tank and only filled it to a few hundred psi you would probably be good.
Cheers
Maree2_99 is offline
post #10 of 11 Old 07-17-2007, 08:08 AM
DILYSI Dave
Check out small welding tanks. They are DOT rated and will hold 2000+ psi. My plan is one of these mounted somewhere out of the way, filled with nitrogen. Regulate it down to 100 psi and inflate tires or run air tools off of it.
DILYSI Dave is offline
post #11 of 11 Old 07-17-2007, 03:07 PM
Bubba Ray
Just get a cheap reg and fill to 1500psi then strap it down good.
Why not a SCUBA Tank for tire inflation? medcop JK Wrangler Technical Forum 40 08-01-2013 12:49 AM
Hard start after Scuba Jeepin' YJake YJ Wrangler Technical Forum 6 07-03-2009 09:11 PM
Co2 vs Scuba tank performance? ghost183 YJ Wrangler Technical Forum 8 03-31-2009 10:09 PM
Scuba tank to fill tires? chris06 TJ Wrangler Technical Forum 10 08-23-2004 10:30 AM
California Tops scuba covers Red97Sport TJ Wrangler Technical Forum 9 07-28-2003 10:34 AM
