Scrambler (cj8) Half-Cab top on a YJ - ANYONE??? - JeepForum.com
post #1 of 9 Old 01-02-2007, 11:07 AM Thread Starter
usafreerider
I am interested in putting a scrambler half cab hard top on my YJ, and am wondering if anyone has done so already. If you have please post pictures and explain any of the complications if there are any in the swap. I can get a half cab top cheap right now, so I want to see if this is going to be an easy or complicated ordeal. Thanks for the help.
usafreerider is offline
post #2 of 9 Old 01-02-2007, 05:17 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
pretty sure the roll bar has to come out which means you'll lose your seat belts (could convert to a lap belt setup for at least some protection). other than that it should bolt right up.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #3 of 9 Old 01-02-2007, 06:07 PM
slater03
Ive seen a picture of it somewhere and it looked sweet but I thinkl he had to take off the rear portion of his rollbar. Theres a company that makes them for Tjs and it also looks sweet.
"Witty quote here"
slater03 is offline
post #4 of 9 Old 01-02-2007, 06:18 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
www.gr8tops.com makes them if i remember right....
you can remove the rear section of your rollbar and use the scrambler one with minor work....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #5 of 9 Old 01-02-2007, 07:56 PM Thread Starter
usafreerider
the GR8Tops tops are only for TJs, or Scrambler full tops. My main concern is the YJ roll bar fitting with the Scrambler half top, but it seems like it will either need to be replaced with a Scrambler roll bar, or I will cut the half top and weather strip it to fit up to the roll bar. Damn, wish it was a direct drop in.
post #6 of 9 Old 01-02-2007, 08:01 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
why not just get the top you want and have a roll bar made? the stock one is inadequate from the factory anyhow and if you're going to be removing from THAT then it will definatly be insufficient in the event of a rollover.
post #7 of 9 Old 01-03-2007, 03:57 PM
kenny kustom
i did. Just cut the roll bar, cut a hole in the top.
pm for more details and pics.
kenny kustom is offline
post #8 of 9 Old 01-03-2007, 06:48 PM Thread Starter
usafreerider
pm'd you. thanks for the help
post #9 of 9 Old 09-12-2011, 07:05 PM
Cambler
1981 CJ7
CJ8 Top
Hey man-
I installed a CJ8 top on my 81 CJ7. I used an older CJ5 roll bar and lap belts. You can also buy a Rock Hard CJ8 inner cab roll cage, but they are a little pricey. Good Luck.
Cambler is offline
Half Top Jeep Scrambler Top ileos79849 YJ Wrangler Technical Forum 11 08-29-2009 06:53 AM
scrambler half top ! dream911tommy YJ Wrangler Technical Forum 19 08-30-2008 10:50 PM
Scrambler half hard top on YJ? tufmar YJ Wrangler Technical Forum 5 10-15-2007 08:05 PM
Scrambler Half top retro-fit smurison14 TJ Wrangler Technical Forum 3 09-27-2006 11:55 AM
scrambler half top Lyle36 YJ Wrangler Technical Forum 3 08-22-2004 01:16 AM
