School me - lockers - Page 2 - JeepForum.com
post #16 of 95 Old 09-27-2013, 07:07 AM
Schaef81
Originally Posted by bogleparsons
I removed my ring gear and did not have to reset my gears.
You didn't replace the carrier that's why
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline
post #17 of 95 Old 09-27-2013, 08:17 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
See, I'm not the only one!
Randonexplosion is offline
post #18 of 95 Old 09-27-2013, 11:08 AM Thread Starter
Rproject
1987 YJ Wrangler
So if it's to be a lunchbox, I'm assuming Spartan is the brand to go with - yes?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #19 of 95 Old 09-27-2013, 11:19 AM
squarelite
They all have the same basic design. I've heard great things about Aussie lockers. I've ran a lock right and grenaded two of them.
squarelite is offline
post #20 of 95 Old 09-27-2013, 11:49 AM Thread Starter
Rproject
1987 YJ Wrangler
Thanks. I just looked at the Aussie. Looks a lot like the Spartan, except better warranty, 100% US made and claims "brake job easy" installation.
Incidentally, how did you imploded the Lock Right's?
1996 White ZJ
Rproject is offline
post #21 of 95 Old 09-27-2013, 01:12 PM
Randonexplosion
Deplorable
I run an Aussie and I like it, but I also installed a Spartan in the back of my friend's full size Bronco. He drives like an ******* and it has stood up just fine.
post #22 of 95 Old 09-27-2013, 01:25 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I usually run Lunchbox lockers before I regear my rigs and go with selectable's
I have run Lockrights in my TJ (They are Junk Grenaded both of them (1) D30 & (1) D35
I ran an Aussie in my 95 It was a nice locker I tried to kill it ended up snapping both rear shafts and bent the housing and the locker held up It's in my buddys XJ now (I swapped in a XJ D44)
My XJ has a Spartan. It was the easiest to install, it is quieter and the pins are huge compaired to the Lockright and Aussie.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #23 of 95 Old 09-27-2013, 01:42 PM Thread Starter
Rproject
1987 YJ Wrangler
OK, great info!!! Now into the stories I've heard of front automatic lockers making driving a new experience in short changing. Is this only in 4wd? How much will it affect 2wd driveability?
1996 White ZJ
Rproject is offline
post #24 of 95 Old 09-27-2013, 01:49 PM
Tom95YJ
Tom95YJ's Avatar
In 4WD on high traction surfaces like rock you'll want to grip the wheel tighter you will feel it pull the front around corners . in 2wd they will be invisible other then some clicking at lowspeeds making tight turns into parking spots
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #25 of 95 Old 09-27-2013, 01:57 PM
Randonexplosion
Deplorable
x2, but never hear a peep out of mine in 2wd.
post #26 of 95 Old 09-27-2013, 02:05 PM Thread Starter
Rproject
1987 YJ Wrangler
I emailed Aussie. Got a response within the hour. They said if I drive in 4wd on pavement in the winter to pull the locker in Dec and reinstall in April. Interesting idea.
1996 White ZJ
Rproject is offline
post #27 of 95 Old 09-27-2013, 02:10 PM
Randonexplosion
Deplorable
I honestly cant contribute on that subject. I didn't get the chance to drive in the snow much last winter before she got torn down for the V8 swap. Trying to turn in the mud in 4wd is a pain so I'd imagine it will feel the same or even worse. Just keeps trying to pull straight...
post #28 of 95 Old 09-27-2013, 02:55 PM
YJames90
YJames90's Avatar
Aussies front and rear on 35. No problem. No, your axle isnt going to explode nor will you do a 360 on ice
My 2.5 to 4.3 swap thread
YJames90 is offline
post #29 of 95 Old 09-27-2013, 03:04 PM Thread Starter
Rproject
1987 YJ Wrangler
Now for the dumb question: Does an Aussie or Spartan fit under the same cover or do I need a new one?
1996 White ZJ
Rproject is offline
post #30 of 95 Old 09-27-2013, 03:08 PM
Randonexplosion
Deplorable
Stock cover will work fine.
