Schaef's 89 YJ "build" - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Schaef's 89 YJ "build"
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 09-06-2012, 08:13 PM   #106
jresch10
You going to carpet or bedline the floor?
2003 Liberty Renegade
2006 Grand Cherokee Laredo
2001 Cherokee Sport
jresch10 is offline   Reply With Quote Quick reply to this message
Unread 09-06-2012, 08:15 PM   #107
schaef89
I'm definitely doing Bedliner. I'm 99% sure my carpet is what caused the rust in the first place
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline   Reply With Quote Quick reply to this message
Unread 09-06-2012, 08:24 PM   #108
jresch10
I would agree. Putting carpet in a Jeep is like putting carpet in a bathroom.
2001 Cherokee Sport
Unread 09-09-2012, 10:49 AM   #109
schaef89
Took a trip to carquest yesterday and picked up a gallon kit of herculiner black.
I was originally going to do Monstaliner tintable in the sand color to match my dash/Rollbar/seat color but then realized all my floor mats were black. I figured the jeep is black so it should look ok still, plus the sand color would have shown dirt like crazy
Unread 09-11-2012, 07:19 PM   #110
schaef89
Small victory.. Got the broken Rollbar bolt out
This happened during Rollbar removal
Used drill bit ascending in size to not mess up the threads.. Wasn't the best but got the job done
Prepping for Bedliner is next but will most likely be put on the back burner for a vacation
Unread 10-07-2012, 11:10 AM   #111
schaef89
Found this when prepping for Bedliner so I welded it up
Prepped and Bedlined
Also started prepping my 91 rollbar to get put in. Picked it up for 30 bucks to work with my tan Rollbar pads
Naval jelly works really well
Unread 10-07-2012, 04:57 PM   #112
BIGHEEP
When I swapped out my rollbar the foot looked the same way. Think about it. In a rollover do you want some rotted sheet metal to be all that is holding the rollbar to the Jeep? Do yourself a favor and do what I did. Get some heavy gauge sheet metal and rebuild the rollbar foot.
1981 Scrambler, Vortec 350,4L60e,D300, Currie 9" F&R
19xx YJ/CJ/TJ/XJ/Waggy thing 4.0L H.O., AW4,
NP231 w/HD SYE,D44 locked/D44 w/LSD,4.09 gears
Build thread http://www.jeepforum.com/forum/f12/m...igheep-534340/
North East Willy Jeep Organization
www.NEWJO.ORG
BIGHEEP is offline   Reply With Quote Quick reply to this message
Unread 10-07-2012, 06:26 PM   #113
schaef89
I did exactly that, just had no pictures of it. That's why I got that naval jelly to dissolve all the rust before I got to patching it. There was no way I was dropping that straight into my jeep without strengthening it back up
Unread 10-07-2012, 06:53 PM   #114
BIGHEEP
www.NEWJO.ORG
Unread 10-08-2012, 04:20 PM   #115
schaef89
Here's a closer look at the texture when it dried. I think it turned out great
Unread 10-08-2012, 09:19 PM   #116
schaef89
Spent the night cleaning up my seat risers. They looked like this before
I used a flap disc on a angle grinder to get all the rust off. Rust converter, rusty metal primer, and rust tough enameled both the passenger and driver seat risers. No pics of the finished product since I was trying to beat the sunset.
By the end of the night I had both front seats bolted in, Rollbar set in place, and rear seat brackets/rear seatbelts in
I have to make a hardware trip for the Rollbar, trans plate, and trans boot
Unread 10-09-2012, 09:24 PM   #117
schaef89
Not an exciting post but ran to lowes for new hardware and bolted the Rollbar down and installed the rear seat
Grade 8s
Unread 10-11-2012, 08:31 AM   #118
schaef89
Prepped my seatbelt brackets for install last night. They were very well rusted so I wire brushed and rust converted then painted. Sorry no before pictures
Also ordered some screws for the transmission plate. Lowes didn't have sheetmetal screws big enough
If anyone's interested the trans access plate is obviously a 5/16 (#16) x 3/4" sheetmetal screw and the shifter boot is a 1/4" (#14) x 1.25" sheet metal screw. 7 are used for each
Unread 10-13-2012, 08:53 AM   #119
Que89YJ
It is looking sweeeeet!
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 10-13-2012, 10:06 AM   #120
pete1991YJ
pete1991YJ's Avatar
OT Hey Que where ya been and hows it going?? Yer a lifetimer now, wow how that happen??
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline   Reply With Quote Quick reply to this message
