Schaef's 89 YJ "build" - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Schaef's 89 YJ "build"
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 08-12-2012, 08:42 AM   #91
schaef89
Headed up to the Bantam Jeep Heritage Festival yesterday. Wasn't expecting to buy anything but spotted a guy selling TJ rubicon flares for 10 bucks a piece but was missing a left rear (said it was cracked). I figured what the hell and bought them anyways since I'd only be in it 30 bucks. I left a little after that due to rain but I was pleased w the purchase.
Looked on eBay last night and saw a left rear for sale so I snatched it up. Looks like the YJ will be getting TJ flares if I ever get the floor finished haha.
Couple of the concept jeeps there. Woulda took more pics but kept forgetting
J-12
Mighty F-C
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline   Reply With Quote Quick reply to this message
Unread 08-15-2012, 09:06 PM   #92
schaef89
Well I obviously didn't make my friday deadline because work ended up getting in the way, but I'm back at it this week
Traced the old panel I cut out
Figured I'd try and weld up the seat bracket/nut. I think it turned out pretty well
Sprayed with some rust converter after being wire wheeled
Trimmed and fit into the gap
And welded in. I had to leave a gap there since it was rusted out and the new panel didn't cover it all. I'll cut another piece it fill it up. I called it quits after I took my welding helmet off and realized it was dark out lol
Unread 08-19-2012, 07:02 PM   #93
schaef89
More progress..
Cut out a patch and fitted to the panel gap
Welded in
Seam sealed
Primered. I wanted to get some protection on these sections because I started to see surface rust form.
On to the driver roll bar area, should be downhill after that part is done
Unread 08-21-2012, 10:19 PM   #94
schaef89
Small update since it was a rainy/wet night in the burgh..
I wanted to unbolt the front half of the wheel well plastic to move out of the way of welding.. So I got my TJ flares out to see what kind of tire coverage I would have
Hopefully wont have much of an issue with inspection
Got my tan Rollbar pads on.. Although they are from a 91 and the seatbelt holes are about two inches off : I'll have to figure out how to handle that later on.. Maybe glue some fabric from behind of similar color. I just put my grab handles and extinguisher on to get them off of shelves for now until I figure a solution
Hole is just under my thumb.
Unread 08-22-2012, 07:45 PM   #95
schaef89
So it's time for the worst of it...
After wire brush
After the hammer
Got the bad cut out.. More to come on this
Side note.. Does anyone know the size bolt for the gas pedal mount?? I seemed to misplace one. Pictured below
Unread 08-22-2012, 08:02 PM   #96
pete1991YJ
pete1991YJ's Avatar
Attachment 458069
If it took a 1/2 inch wrench then its 5/16-18. *Most* of the jeep body is this size. If it took a 7/16 wrench then its a 1/4-20. Hope this helps. PS thats some impressive rust yer dealing with there... it reminds me of work
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline   Reply With Quote Quick reply to this message
Unread 08-22-2012, 08:26 PM   #97
schaef89
Thanks pete.. I was thinking 1/4-20 myself. I just wanted to pick everyone's brain to confirm my guess
And I'm definitely getting surprised w how much rust it has as well
Unread 08-26-2012, 03:51 PM   #98
schaef89
Update after this weekends activities..
My support channel was a little worse for wear so I cut out the bad parts and welded in new
Fixed. And also got this so I don't catch myself on fire since I was welding directly over fuel lines
Rust converter on the channel
First piece welded in
Fully welded in
Seam sealed and primered.
Glad to have the worst out of the way. Passenger side is next!
Unread 09-05-2012, 07:33 PM   #99
schaef89
Update time.. Passenger side Rollbar footing
the lady wanted to help
Had to bend up a piece of 16 gauge since I didn't buy a replacement panel. Not too bad for only having a bench vise I think
Welded
Unread 09-05-2012, 08:34 PM   #100
jresch10
This thread ROCKS! I bought an '89 YJ a few weeks ago and I'm going to have to replace the drivers side floor pan and the section where the left side of the seat riser mounts as well. I also have a section in the rear right corner of the floor back by the tail gate to replace. Never welded before in my life but I think I can learn. Thanks for the thread!
jresch10 is offline   Reply With Quote Quick reply to this message
Unread 09-06-2012, 08:23 AM   #101
schaef89
Thank you sir. I actually haven't welded much of anything previous to this jeep rusting out (besides a semester course in hs). But it's def a learning process for me and I hope to get better as I go. Good luck with your floor!
Unread 09-06-2012, 09:24 AM   #102
jresch10
Are you using flux core or MIG?
2003 Liberty Renegade
2006 Grand Cherokee Laredo
2001 Cherokee Sport
Unread 09-06-2012, 09:42 AM   #103
schaef89
Hobart flux core (MIG capable)
Unread 09-06-2012, 02:21 PM   #104
Paranoia55
Hell yeah another 89
Paranoia55 is offline   Reply With Quote Quick reply to this message
Unread 09-06-2012, 07:57 PM   #105
schaef89
Last bit of rust..
Cleaned up for sealer and paint
And this means the floor is 100% completed! I will celebrate with some relaxation a few of these
so pumped its done.
