Schaef's 89 YJ "build" - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Schaef's 89 YJ "build"
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 07-05-2012, 06:54 PM   #76
schaef89
Update time.. So I ended up getting a 90* die grinder with an arbor attachment to cut my floor out. It worked like a charm!
It was pretty time consuming though, took me 2 hours to cut it out with waiting for my compressor to catch up. Getting tired of waiting on that thing
I also found out that the panel is spot welded to these braces. I had no idea these were there
I laid the cut out panel inside the new one to use as a template.
I finished tracing it out and couldn't take the heat anymore. I'll cut this out tomorrow after a half day of work and start to weld it in!
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline   Reply With Quote Quick reply to this message
Unread 07-06-2012, 05:38 PM   #77
schaef89
Traced out in a color I can actually see
Cut out
Got it partially welded in before calling it quits for the day.
Unread 07-08-2012, 08:18 PM   #78
Que89YJ
Its lookin' good Shaef.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 07-09-2012, 08:24 AM   #79
schaef89
Thanks que.. How's yours coming along?
Unread 07-09-2012, 08:53 AM   #80
Que89YJ
Put on hold. I am in the middle of moving. Trying to move all the tools and jeep stuff in the garage is going to be a week long effort by itself. It's been all work and no play so far this year.
Unread 07-10-2012, 08:51 PM   #81
schaef89
If your garage looks anything like mine I can only imagine haha
Unread 08-06-2012, 08:46 PM   #82
schaef89
So after vacations and business travel got in the way, I told myself I'd get this jeep ready for Bedliner by Friday.
Today's progress..
All welded in except for a section I cut too wide for the replacement panel (I'll patch that w part of the old panel)
And this because I thought the pic looked cool. Taken while cleaning up at sundown
Unread 08-06-2012, 08:53 PM   #83
mark0530
That looks like my floor. Just got the replacement panel in. Nice job on the welds. I don't think I good enough to butt weld like you did. Probably do an overlap.
mark0530 is offline   Reply With Quote Quick reply to this message
Unread 08-06-2012, 08:57 PM   #84
schaef89
Thanks man. I actually did a quarter inch overlap on about half of the panel though. I guess the picture is just making it look better than it is, which I'll take lol
Unread 08-06-2012, 09:07 PM   #85
mark0530
I'll shoot you a pic of mine. Driver almost completely gone. Even some soft spots by seat brackets and hole by the rollbar. Luckily I have a 3x4 piece of sheet metal and a formed floor pan. Guess that's what you get for $1600.
Unread 08-06-2012, 09:11 PM   #86
schaef89
Haha I know what you mean. My driver side is terrible. Passenger still bad but not good by any means. Mine was a product of road salt
Unread 08-07-2012, 08:10 PM   #87
schaef89
Today's activities..
Got the panel gap filled. Not perfect but it'll do
Next task was the floor under the driver seat
I marked lines where the seat holes were so I could line them back up when welding in the new panel
Cut out
Started vacuuming out most of the rust chips and start gettin more and more of these lol
From here (seat support channel looking towards the rear of the jeep)
I can't reach them to get them out so I'll have to wait until I cut out the Rollbar foot area to get at them with the vacuum. I'm just amazed they were in there because it's next to impossible for something to get in that area
Has anyone repaired the broken plate that has the rear bolt welded to it? I've seen a lot of floor replacements on here but not so much for that bracket. I'll most likely cut it out and weld in a new nut and plate. Here's the bracket
Unread 08-08-2012, 09:39 AM   #88
Que89YJ
That looks great! 2 week and my move will be done and I can start to play with the YJ. I wish you lived a little closer. I sure could use your help with the welding. That repair looks awesome!
Unread 08-08-2012, 08:28 PM   #89
schaef89
Thanks a lot Que. I'm still learning the ropes with welding, but I'll get the hang of it sooner or later. Do you have a build thread on here somewhere?
Unread 08-08-2012, 10:09 PM   #90
Que89YJ
No. I will start one when the move is over on a couple weeks. It's been a long year for me.
