Schaef's 89 YJ "build" - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Schaef's 89 YJ "build"
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 11-16-2012, 09:27 PM   #151
schaef89
Got these for a STEAL off Craigslist
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline   Reply With Quote Quick reply to this message
Unread 11-16-2012, 09:48 PM   #152
jresch10
Are those Besttop seats?
2003 Liberty Renegade
2006 Grand Cherokee Laredo
2001 Cherokee Sport
jresch10 is offline   Reply With Quote Quick reply to this message
Unread 11-16-2012, 09:58 PM   #153
schaef89
Yes sir
Unread 11-16-2012, 10:10 PM   #154
jresch10
Nice find!
2001 Cherokee Sport
Unread 11-17-2012, 02:55 AM   #155
stratostix
I just spent the past hour reading your build/restoration. Looks like you've put a lot of hours into it. Thats great dedication. Good luck on the rest of your build. It's looking great so far!
1994 YJ
1965 Mustang Coupe Hi-po
2003 BMW 325i
[QUOTE=Anticanman;14148985]If they're gonna bend you over for that much, I'd definitely pay extra for the lube!![/QUOTE]
Jeep Build thread:
[url]http://www.jeepforum.com/forum/f12/94-yj-build-thread-1234264/[/url]
stratostix is offline   Reply With Quote Quick reply to this message
Unread 11-17-2012, 08:29 AM   #156
soonermatt
These are the best kind. The wife generally approves of these purchases too. When I change my mind I can sell the stuff for cost or profit. I know the good feeling.
soonermatt is offline   Reply With Quote Quick reply to this message
Unread 11-17-2012, 03:35 PM   #157
schaef89
Got a bunch of work done today..
Got the seats installed! They are comfortable as hell. I was worried about then matching the interior but I think they look good
I moved on to spend some quality time with my intake and cleaned it up
Then onto cleaning the vacuum line assembly. Found a completely dry rotted hose as well and replaced it
The spring clip actually broke in two when I tried to remove it.. I wonder how long this hose has been there
I also degreased and de-rtv'd the valve cover in preparation for getting the head back next week. No pics of that though
Unread 11-17-2012, 03:41 PM   #158
schaef89
Thanks! I've been following your 94 thread as well. Keep up the good work. Sometimes I wish I could do more modifications like you, but recently mine's been focused on creating a *working* jeep haha
Unread 11-17-2012, 05:11 PM   #159
stratostix
I hear u. It all depends on what ur workin with. Thankfully my rust issues r minimal compared to urs. Ur definitely going in the right order. Cant be modding a rust bucket.
1994 YJ
2003 BMW 325i
Jeep Build thread:
Unread 11-17-2012, 08:25 PM   #160
Opihi59
from here it gets rough
Opihi59's Avatar
Looked at the photos you posted up of your combustion chambers. Not sure why your #1 exhaust valve is so clean looking--only time I've seen that difference is if there has been coolant getting in there like in a blown head gasket, or a crack in the cylinder in that chamber. Of course, that doesn't seem to match your Intake valve in #1 so not sure what to make of it. Anyway, that's just an anecdote, and likely not the norm. I am sure the machine shop will test your head for cracks (pressure test, magnaflux) before they do a rebuild on it.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline   Reply With Quote Quick reply to this message
Unread 11-20-2012, 10:03 PM   #161
schaef89
Got the head back today.. The machinist said he had to put 4 seats in and 3 completely new valves. He said it was real bad
No pics yet but I'll post some soon
Unread 11-21-2012, 08:07 AM   #162
schaef89
So I think I heard the machinist wrong. Looking at it I think it was 4 new valves and 3 seats. Either way I stopped off at advance last night to get some engine paint to finish this off before I install.
Unread 12-02-2012, 10:29 PM   #163
Craus
Impressive thread..thanks for all the pics and details of your work. Floors turned out great. I kind of thought you might have swapped your other jeeps engine after you pulled the head on the 4 cyl. But with these gas prices I wouldn't mind a 4 cyl right now myself
Craus is offline   Reply With Quote Quick reply to this message
Unread 12-03-2012, 06:31 AM   #164
schaef89
Thank you! I wasn't really thinking about that swap until i started having problems w the timing after i put the reman head in. Im still trying to track it down.. I even pulled the timing cover again to make 100% sure i did that right. I think I have it down to distributor position.
When i looked into using the 93 as a donor I wasn't too fond of the 32rh. If I didn't want to use it I would have had to find an ax15, computer, driveshafts, etc. Seemed like more work than I wanted to do in the winter, especially when I'll be moving into a new place in a couple months.
Unread 12-03-2012, 08:00 AM   #165
responder
I read the entire thread this morning. Good job on your project! Chasing engine problems, or any problem for that matter, is never fun. Looks like you are getting a handle on it though.
responder is offline   Reply With Quote Quick reply to this message
