Schaef's 89 YJ "build" - Page 9 - JeepForum.com
post #121 of 291 Old 10-13-2012, 09:15 AM Thread Starter
schaef89
Originally Posted by Que89YJ
It is looking sweeeeet!
Thank you sir. How's yours coming along??
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #122 of 291 Old 10-17-2012, 03:44 PM Thread Starter
schaef89
Hardtop is back on for winter and the last important interior pieces (trans plate and shifter boots) were bolted down today
I'll have to touch up the edge when I get a chance.
It'll be off for inspection again this year shortly. At least I have a half month to spare this time unlike last year.
schaef89 is offline
post #123 of 291 Old 10-22-2012, 09:50 AM
Que89YJ
It is looking real good!
Que89YJ is offline
post #124 of 291 Old 10-24-2012, 05:41 AM Thread Starter
schaef89
I wanted to try and fix my ongoing rough idle before I took it for inspection. I've tried just about everything and decided to reset the timing chain to see if that helped. Here's what I found when I pulled the timing cover at TDC
180 out. I kicked myself for not double checking this last year when I did the chain
Got the camshaft turned and aligned
I knew my vibration damper bolt was in bad shape but didn't realize it was this bad. Ended up running a tap through the crank and putting a new 1/2-20 bolt in there. Tightened down good enough
All said and done the idle was a lot smoother but I still have a stumble when I first hit the gas/on takeoff. At least the motor isn't shaking the whole car at stop lights anymore
schaef89 is offline
post #125 of 291 Old 11-03-2012, 08:52 AM Thread Starter
schaef89
I couldn't get my inspection scheduled this week so I decided to start doing tests on the motor since fixing the timing. Started with pulling the plugs and did compression (again)
Not promising.
Cylinder 1. 120 psi
Cylinder 2. 100 psi
Cylinder 3. 60 psi
Cylinder 4. 100 psi
Cylinder 1 is really the only good number for a dry test. Cylinder 3 just sucks.
I'm gonna look into options for replacing the 2.5 I think. Even if I pull the head and get that looked over the rings might be toast. Maybe I'll run a wet test to try and isolate the problem between the rings and the head before popping on a new motor.
image-709405204.jpg   image-4095090587.jpg   image-104484379.jpg   image-4150776005.jpg
schaef89 is offline
post #126 of 291 Old 11-04-2012, 08:38 AM
PA_YJ19
Ouch 60 is no good, ever think bout just putting a 4.0 in it? Pretty easy to find a 4.0 at a JY around here n it would allow u to upgrade to a better tranny as well. Just a thought, u could bore out the 2.5 n rebuild a little monster. Don't think that we b cost efficient tho. I do see 2.5s on craiglist quiet a bit around here tho, u might b able to find one sum1 pulled out to put a larger motor in.
PA_YJ19 is offline
post #127 of 291 Old 11-05-2012, 07:11 AM
jresch10
Your bed lined tub turned out great!
2003 Liberty Renegade
2006 Grand Cherokee Laredo
2001 Cherokee Sport
jresch10 is offline
post #128 of 291 Old 11-05-2012, 07:12 AM
jresch10
How's that seat mount bracket/nut that you welded holding up? Looks like mine needs repaired as well.
2001 Cherokee Sport
jresch10 is offline
post #129 of 291 Old 11-05-2012, 08:58 AM
Que89YJ
You need to check it wet by squirting some oil down inside each cylinder and rechecking it. You could have a valve/lifter issue or a ring issue.
Que89YJ is offline
post #130 of 291 Old 11-05-2012, 09:38 AM Thread Starter
schaef89
I've thought about putting a 4.0 in it since i've had the jeep haha. But all things considered I have 4.88s r&p's sitting in my garage for regearing and I don't want to get into that much of a project at this point. I could always sell the 4.88s but I would need a parts jeep to do the 4.0 swap (just easier), and I don't have the space to have it sitting around. I'm talking to a couple of buddies about good machine shops around the PGH area so I'm starting there.
Attachment 502188
Yeah it's holding up fine. Yours looks exactly like mine did before I welded it back up. I was concerned when I was wrenching the bolt back down when installing the seats but it didn't break.
And thanks about the bedliner. I was real happy with how it turned out and hopefully my floor will be protected from here on out
Honestly I think it's both Que. But I plan to do the wet test tonight after work. I didn't have a chance to check it this weekend and was too lazy to mess with oil when i got those numbers
I also had to organize the garage for an upcoming winter project (gotta get some work done to the 93 to get it roadworthy )
schaef89 is offline
post #131 of 291 Old 11-05-2012, 09:50 AM
Que89YJ
I wish you lived a little closer. You do great work. I could use some of your help getting my tub strait.
Que89YJ is offline
post #132 of 291 Old 11-05-2012, 10:05 AM Thread Starter
schaef89
Thanks for that Que. What are you working on now? Last thing I remember you saying was you were taking the tailgate off
schaef89 is offline
post #133 of 291 Old 11-05-2012, 12:48 PM
Que89YJ
I got the whole tailgate corner area ripped apart. Maybe now I can finally put it back together before the next disaster hits! LOL I need to do some cutting on the fenders for the Xenon flares. I am not just feeding your ego. You do great work. The welding thing bothers me because I really am just learning and my welds look like crap.
Que89YJ is offline
post #134 of 291 Old 11-05-2012, 01:47 PM Thread Starter
schaef89
Much appreciated Until I started welding on the jeep I old had a semester welding course in high school. I just took my time and learned as I went because there was no way I wanted to pay someone else to do it. It's not perfect at all but serves my purposes. I'm sure you'll do just fine if you do the same
Are you using a mig?
schaef89 is offline
post #135 of 291 Old 11-05-2012, 03:18 PM
Que89YJ
Yes. I got a lincoln 140 with a full bottle and cart for 350. I want to do it myself but its always god to have someone who knows what they are doing to help. I am with you on paying someone besides it kind of something I take pride in when it's done knowing that I did it.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
LJ Build "Sylvia" another stretch on tons, COs, Hemi Swap-- EVENTUALLY VecoPlan TJ Wrangler Technical Forum 322 11-18-2013 09:20 AM
What could i build out of my broken hardtop? maybe a "hard" bikini top ..etc..?? BigDeaner YJ Wrangler Technical Forum 4 08-25-2010 11:00 PM
My Build, Best Money EVER Spent! 33" Rockers, 2.5" RC lift... rastaangel TJ Wrangler Technical Forum 1 04-11-2010 10:13 PM
Direction advice for my "newb" build from the experts outlanderbz TJ Wrangler Technical Forum 16 08-25-2009 07:05 PM
"Heavy Duty" Springs listed on build sheet? IAJack TJ Wrangler Technical Forum 2 11-01-2005 05:53 AM
