Schaef's 89 YJ "build" - Page 8 - JeepForum.com
post #106 of 291 Old 09-06-2012, 07:13 PM
jresch10
You going to carpet or bedline the floor?
2003 Liberty Renegade
2006 Grand Cherokee Laredo
2001 Cherokee Sport
jresch10 is offline
post #107 of 291 Old 09-06-2012, 07:15 PM Thread Starter
schaef89
I'm definitely doing Bedliner. I'm 99% sure my carpet is what caused the rust in the first place
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #108 of 291 Old 09-06-2012, 07:24 PM
jresch10
I would agree. Putting carpet in a Jeep is like putting carpet in a bathroom.
2001 Cherokee Sport
jresch10 is offline
post #109 of 291 Old 09-09-2012, 09:49 AM Thread Starter
schaef89
Took a trip to carquest yesterday and picked up a gallon kit of herculiner black.
I was originally going to do Monstaliner tintable in the sand color to match my dash/Rollbar/seat color but then realized all my floor mats were black. I figured the jeep is black so it should look ok still, plus the sand color would have shown dirt like crazy
schaef89 is offline
post #110 of 291 Old 09-11-2012, 06:19 PM Thread Starter
schaef89
Small victory.. Got the broken Rollbar bolt out
This happened during Rollbar removal
Used drill bit ascending in size to not mess up the threads.. Wasn't the best but got the job done
Prepping for Bedliner is next but will most likely be put on the back burner for a vacation
schaef89 is offline
post #111 of 291 Old 10-07-2012, 10:10 AM Thread Starter
schaef89
Found this when prepping for Bedliner so I welded it up
Prepped and Bedlined
Also started prepping my 91 rollbar to get put in. Picked it up for 30 bucks to work with my tan Rollbar pads
Naval jelly works really well
schaef89 is offline
post #112 of 291 Old 10-07-2012, 03:57 PM
BIGHEEP
When I swapped out my rollbar the foot looked the same way. Think about it. In a rollover do you want some rotted sheet metal to be all that is holding the rollbar to the Jeep? Do yourself a favor and do what I did. Get some heavy gauge sheet metal and rebuild the rollbar foot.
1981 Scrambler, Vortec 350,4L60e,D300, Currie 9" F&R
19xx YJ/CJ/TJ/XJ/Waggy thing 4.0L H.O., AW4,
NP231 w/HD SYE,D44 locked/D44 w/LSD,4.09 gears
Build thread
North East Willy Jeep Organization
BIGHEEP is offline
post #113 of 291 Old 10-07-2012, 05:26 PM Thread Starter
schaef89
I did exactly that, just had no pictures of it. That's why I got that naval jelly to dissolve all the rust before I got to patching it. There was no way I was dropping that straight into my jeep without strengthening it back up
schaef89 is offline
post #114 of 291 Old 10-07-2012, 05:53 PM
BIGHEEP
Build thread
BIGHEEP is offline
post #115 of 291 Old 10-08-2012, 03:20 PM Thread Starter
schaef89
Here's a closer look at the texture when it dried. I think it turned out great
schaef89 is offline
post #116 of 291 Old 10-08-2012, 08:19 PM Thread Starter
schaef89
Spent the night cleaning up my seat risers. They looked like this before
I used a flap disc on a angle grinder to get all the rust off. Rust converter, rusty metal primer, and rust tough enameled both the passenger and driver seat risers. No pics of the finished product since I was trying to beat the sunset.
By the end of the night I had both front seats bolted in, Rollbar set in place, and rear seat brackets/rear seatbelts in
I have to make a hardware trip for the Rollbar, trans plate, and trans boot
schaef89 is offline
post #117 of 291 Old 10-09-2012, 08:24 PM Thread Starter
schaef89
Not an exciting post but ran to lowes for new hardware and bolted the Rollbar down and installed the rear seat
Grade 8s
schaef89 is offline
post #118 of 291 Old 10-11-2012, 07:31 AM Thread Starter
schaef89
Prepped my seatbelt brackets for install last night. They were very well rusted so I wire brushed and rust converted then painted. Sorry no before pictures
Also ordered some screws for the transmission plate. Lowes didn't have sheetmetal screws big enough
If anyone's interested the trans access plate is obviously a 5/16 (#16) x 3/4" sheetmetal screw and the shifter boot is a 1/4" (#14) x 1.25" sheet metal screw. 7 are used for each
schaef89 is offline
post #119 of 291 Old 10-13-2012, 07:53 AM
Que89YJ
It is looking sweeeeet!
Que89YJ is offline
post #120 of 291 Old 10-13-2012, 09:06 AM
pete1991YJ
OT Hey Que where ya been and hows it going?? Yer a lifetimer now, wow how that happen??
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
LJ Build "Sylvia" another stretch on tons, COs, Hemi Swap-- EVENTUALLY VecoPlan TJ Wrangler Technical Forum 322 11-18-2013 09:20 AM
What could i build out of my broken hardtop? maybe a "hard" bikini top ..etc..?? BigDeaner YJ Wrangler Technical Forum 4 08-25-2010 11:00 PM
My Build, Best Money EVER Spent! 33" Rockers, 2.5" RC lift... rastaangel TJ Wrangler Technical Forum 1 04-11-2010 10:13 PM
Direction advice for my "newb" build from the experts outlanderbz TJ Wrangler Technical Forum 16 08-25-2009 07:05 PM
"Heavy Duty" Springs listed on build sheet? IAJack TJ Wrangler Technical Forum 2 11-01-2005 05:53 AM
