Schaef's 89 YJ "build" - Page 7 - JeepForum.com
post #91 of 291 Old 08-12-2012, 07:42 AM Thread Starter
schaef89
Headed up to the Bantam Jeep Heritage Festival yesterday. Wasn't expecting to buy anything but spotted a guy selling TJ rubicon flares for 10 bucks a piece but was missing a left rear (said it was cracked). I figured what the hell and bought them anyways since I'd only be in it 30 bucks. I left a little after that due to rain but I was pleased w the purchase.
Looked on eBay last night and saw a left rear for sale so I snatched it up. Looks like the YJ will be getting TJ flares if I ever get the floor finished haha.
Couple of the concept jeeps there. Woulda took more pics but kept forgetting
J-12
Mighty F-C
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #92 of 291 Old 08-15-2012, 08:06 PM Thread Starter
schaef89
Well I obviously didn't make my friday deadline because work ended up getting in the way, but I'm back at it this week
Traced the old panel I cut out
Figured I'd try and weld up the seat bracket/nut. I think it turned out pretty well
Sprayed with some rust converter after being wire wheeled
Trimmed and fit into the gap
And welded in. I had to leave a gap there since it was rusted out and the new panel didn't cover it all. I'll cut another piece it fill it up. I called it quits after I took my welding helmet off and realized it was dark out lol
schaef89 is offline
post #93 of 291 Old 08-19-2012, 06:02 PM Thread Starter
schaef89
More progress..
Cut out a patch and fitted to the panel gap
Welded in
Seam sealed
Primered. I wanted to get some protection on these sections because I started to see surface rust form.
On to the driver roll bar area, should be downhill after that part is done
schaef89 is offline
post #94 of 291 Old 08-21-2012, 09:19 PM Thread Starter
schaef89
Small update since it was a rainy/wet night in the burgh..
I wanted to unbolt the front half of the wheel well plastic to move out of the way of welding.. So I got my TJ flares out to see what kind of tire coverage I would have
Hopefully wont have much of an issue with inspection
Got my tan Rollbar pads on.. Although they are from a 91 and the seatbelt holes are about two inches off : I'll have to figure out how to handle that later on.. Maybe glue some fabric from behind of similar color. I just put my grab handles and extinguisher on to get them off of shelves for now until I figure a solution
Hole is just under my thumb.
schaef89 is offline
post #95 of 291 Old 08-22-2012, 06:45 PM Thread Starter
schaef89
So it's time for the worst of it...
After wire brush
After the hammer
Got the bad cut out.. More to come on this
Side note.. Does anyone know the size bolt for the gas pedal mount?? I seemed to misplace one. Pictured below
schaef89 is offline
post #96 of 291 Old 08-22-2012, 07:02 PM
pete1991YJ
Attachment 458069
If it took a 1/2 inch wrench then its 5/16-18. *Most* of the jeep body is this size. If it took a 7/16 wrench then its a 1/4-20. Hope this helps. PS thats some impressive rust yer dealing with there... it reminds me of work
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #97 of 291 Old 08-22-2012, 07:26 PM Thread Starter
schaef89
Thanks pete.. I was thinking 1/4-20 myself. I just wanted to pick everyone's brain to confirm my guess
And I'm definitely getting surprised w how much rust it has as well
schaef89 is offline
post #98 of 291 Old 08-26-2012, 02:51 PM Thread Starter
schaef89
Update after this weekends activities..
My support channel was a little worse for wear so I cut out the bad parts and welded in new
Fixed. And also got this so I don't catch myself on fire since I was welding directly over fuel lines
Rust converter on the channel
First piece welded in
Fully welded in
Seam sealed and primered.
Glad to have the worst out of the way. Passenger side is next!
schaef89 is offline
post #99 of 291 Old 09-05-2012, 06:33 PM Thread Starter
schaef89
Update time.. Passenger side Rollbar footing
the lady wanted to help
Had to bend up a piece of 16 gauge since I didn't buy a replacement panel. Not too bad for only having a bench vise I think
Welded
schaef89 is offline
post #100 of 291 Old 09-05-2012, 07:34 PM
jresch10
This thread ROCKS! I bought an '89 YJ a few weeks ago and I'm going to have to replace the drivers side floor pan and the section where the left side of the seat riser mounts as well. I also have a section in the rear right corner of the floor back by the tail gate to replace. Never welded before in my life but I think I can learn. Thanks for the thread!
jresch10 is offline
post #101 of 291 Old 09-06-2012, 07:23 AM Thread Starter
schaef89
Thank you sir. I actually haven't welded much of anything previous to this jeep rusting out (besides a semester course in hs). But it's def a learning process for me and I hope to get better as I go. Good luck with your floor!
schaef89 is offline
post #102 of 291 Old 09-06-2012, 08:24 AM
jresch10
Are you using flux core or MIG?
2003 Liberty Renegade
2006 Grand Cherokee Laredo
2001 Cherokee Sport
jresch10 is offline
post #103 of 291 Old 09-06-2012, 08:42 AM Thread Starter
schaef89
Hobart flux core (MIG capable)
schaef89 is offline
post #104 of 291 Old 09-06-2012, 01:21 PM
Paranoia55
Hell yeah another 89
Paranoia55 is offline
post #105 of 291 Old 09-06-2012, 06:57 PM Thread Starter
schaef89
Last bit of rust..
Cleaned up for sealer and paint
And this means the floor is 100% completed! I will celebrate with some relaxation a few of these
so pumped its done.
schaef89 is offline
LJ Build "Sylvia" another stretch on tons, COs, Hemi Swap-- EVENTUALLY VecoPlan TJ Wrangler Technical Forum 322 11-18-2013 09:20 AM
What could i build out of my broken hardtop? maybe a "hard" bikini top ..etc..?? BigDeaner YJ Wrangler Technical Forum 4 08-25-2010 11:00 PM
My Build, Best Money EVER Spent! 33" Rockers, 2.5" RC lift... rastaangel TJ Wrangler Technical Forum 1 04-11-2010 10:13 PM
Direction advice for my "newb" build from the experts outlanderbz TJ Wrangler Technical Forum 16 08-25-2009 07:05 PM
"Heavy Duty" Springs listed on build sheet? IAJack TJ Wrangler Technical Forum 2 11-01-2005 05:53 AM
