Schaef's 89 YJ "build" - Page 13 - JeepForum.com
post #181 of 291 Old 01-14-2013, 06:00 AM Thread Starter
schaef89
It was nice out yesterday so I popped the hood on the jeep and looked over the connections. Verified that everything was connected and that the pigtails weren't corroded. Everything looked good, so the next step is to start testing sensors. I'm going to start with cts and o2 as Que suggested. Before I do that I want to punch out the cat to make sure I don't have exhaust restrictions during tests (got red hot twice now, so it's got to go either way).
I also might check for weak spark, but have to grab a spark tester next time I'm at the parts store.
Oh, and my valve cover is leaking as well.. lol :
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #182 of 291 Old 01-14-2013, 06:05 AM
Que89YJ
I hope your new place has garage space.It's going to be cold in Pitt!
Que89YJ is offline
post #183 of 291 Old 01-14-2013, 09:29 AM Thread Starter
schaef89
It does have garage space.. The Problem is my 93 is currently in there awaiting it's fate, as well as a storage locker full of boxes/containers But it's actually been in the 50s and 60s lately here (65 yesterday) which has been really nice.
I'm currently working on the 89 on a grassy hill next to my driveway. I think the jeep would be about 6" too tall for the garage anyways. I haven't measured but I'm pretty sure it's only a 6' high opening lol
schaef89 is offline
post #184 of 291 Old 01-14-2013, 10:16 AM
Que89YJ
LOL you are not all that far from me in Michigan. That 60 degree weather is just trying to pull you outside and then....reality of a northern winter and 20 degrees highs set in! I havent heard you talk about the 93 at all. Is it a future project Jeep?
Que89YJ is offline
post #185 of 291 Old 01-14-2013, 11:59 AM Thread Starter
schaef89
I haven't talked about it much on here other than post #59 and glimpses of it in the background of pictures. I also did start a thread with my intended plan, but that has since fell by the wayside.
I got it from a straight across trade for my old 00 cavalier. It's a 4.0l, auto, abs, A/C YJ. I got it with the intent of fixing it up for my sister who's turning 16 next year. It needs body sheetmetal patches and (what I thought) easy frame welding. Turns out the frame is beyond fixing, having angle iron welded under the skid plate holding it together, etc etc. I went as far as getting a replacement frame but kept finding things that would nickel and dime the project. This consequently made the body a lost cause, having rusted out fenders, rear valance, and some floor sections. It also burns oil bad because the PO thought it was ok to run it 4 quarts low (found that gem in my driveway after the trade). It was just beat.
So I'm contemplating parting it out slowly or selling whole. Or keeping what I need for a 4.0 swap, rebuilding the engine and putting it into my 89. All I would need is a manual computer and ax-15, maybe driveshafts. Then parting out the rest. I just hate to kill it because it really does drive nice, just had a rough life.
schaef89 is offline
post #186 of 291 Old 01-14-2013, 12:37 PM
Que89YJ
Sounds to me like the electrical system and the trans/tcase is salvagable for a 4.0L swap but the rest of it should be let go. You should be able to find a better engine for a swap then one that has been beat up. Find your sis a more reliable Jeep. The last thing you want is her driving a Jeep in the cold and have to worry about it being unreliable.
Que89YJ is offline
post #187 of 291 Old 01-14-2013, 02:01 PM Thread Starter
schaef89
That was my reasoning exactly Not too keen on the auto though. I'd def want to wait for a 5spd to come along if I set my mind to the swap. If I can't get this 4 banger to run right I might just dive in lol. Chances are it's something I overlooked hooking up or a bad sensor as you said earlier so we'll see
schaef89 is offline
post #188 of 291 Old 01-16-2013, 06:30 AM Thread Starter
schaef89
I did some research on my issue last night and checked some things over. The injector is definitely not stuck open so I'll move onto the cts resistance test tonight.
schaef89 is offline
post #189 of 291 Old 02-10-2013, 03:26 PM Thread Starter
schaef89
Since we got a heat wave here in Pittsburgh (50 deg) I headed outside to do some testing.
blocked exhaust check
I started by punching out the cat to rule out a blocked exhaust. Turns out it was blocked as my throttle response went from non-existent to marginal.
spark plugs/wires test
I started pulling spark plugs and testing plug wire resistances
#1 plug wire resistance: 5.45k Ohm
#2 plug wire resistance: 5.65k Ohm
#3 plug wire resistance: 6.33k Ohm
#4 plug wire resistance: 5.11k Ohm
Coil/Dist wire resistance: 5.71k Ohm
I'm not quite sure what the resistance should be but after some research online it looks like the resistances should be about 4-5k ohms per 1 foot of wire? If that's the case then I need to replace all of them because most of the wires are only 8" long
I've also swapped the #3 and #2 plug wire and it seems that the look of the plug swapped (wet on 2 was now dry, dry on 3 was now wet). So I think I have inconsistent spark on #2 caused by the wire
o2 sensor test
The o2 sensor was tested between terminals A and B (yellow and black) and found a resistance of 7.3 ohms (spec says 5-7 ohms). It looks like my o2 is slightly out of spec and should be up for replacement.
I also measured between gray and black and got 158 ohms. I'm not sure what this was supposed to measure because the book says nothing about these terminals as far as i read.
cts sensor test
The cts in the jeep now tested at 1.42k Ohms and the temp sensor showed below 100* (although I think the temp sensor wire may be faulty after the head install). This was also after running it for 5 min and driving around the block, however the manifold was just warm to the touch. I'll have to double check the one in there when the jeep is completely cold.
I've bench tested the other two sensors i have (old stock one, and spare i had). At outside temp (50*) they both had a reading of 6.5k ohms, then i put my hand around one while measuring and it went to 2.5k ohms at body temp. This seems that both are in working order so I have good replacements if the one in the jeep is bad.
other news
My Voltmeter gauge no longer works lol. However I verified with a voltmeter that the battery is charging at 14.5v. So i have a wiring issue somewhere in the charging circuit
As stated above I think my temp gauge is no longer reading correctly. I'll have to see if the sending unit has a test i can run or if it's the wire
schaef89 is offline
post #190 of 291 Old 02-10-2013, 03:33 PM
Que89YJ
It's a resistance check for the temp sensor. The o2 sounds fine. Not quite that warm here yet. Keep giving all the good info. I am going to use your info when I pull my tub in a couple weeks and start my fiberglass tub.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #191 of 291 Old 02-10-2013, 03:40 PM Thread Starter
schaef89
I didn't know you were going fiberglass. Your tub too far gone?
schaef89 is offline
post #192 of 291 Old 02-10-2013, 04:53 PM
Que89YJ
The tub has no rust but needs some work. I got a deal on the glass I couldn't pass up. Everything new in the box: fenders, tub, windshield, glass and rubber for 1500. I an dealing with a 6 year old car showing rust from the salt. Since I needed to pull the tub anyways to do the repair I am going to do the glass.
Fault codes:
No Start:
Que89YJ is offline
post #193 of 291 Old 02-10-2013, 08:01 PM
pete1991YJ
Wow that *is* a good deal... now you are gonna have to run separate ground wires for everything tho, since the glass doesn't conduct...
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #194 of 291 Old 02-21-2013, 06:32 AM Thread Starter
schaef89
So I went through the FSM and came up with this for testing spark plug wires
Before I found that I went out and grabbed a new set of wires and since finding that I figured I'd test them. The tested WORSE than the ones in my jeep so they'll be going back today
I did pick up a set of stock champion coppers to throw in. I'm thinking the autolites in there may be bad. And I'll do another compression test while replacing the plugs just to triple check
schaef89 is offline
post #195 of 291 Old 02-21-2013, 07:00 AM
Que89YJ
They usually run 6/9k ohm.
Fault codes:
No Start:
Que89YJ is offline
LJ Build "Sylvia" another stretch on tons, COs, Hemi Swap-- EVENTUALLY VecoPlan TJ Wrangler Technical Forum 322 11-18-2013 09:20 AM
What could i build out of my broken hardtop? maybe a "hard" bikini top ..etc..?? BigDeaner YJ Wrangler Technical Forum 4 08-25-2010 11:00 PM
My Build, Best Money EVER Spent! 33" Rockers, 2.5" RC lift... rastaangel TJ Wrangler Technical Forum 1 04-11-2010 10:13 PM
Direction advice for my "newb" build from the experts outlanderbz TJ Wrangler Technical Forum 16 08-25-2009 07:05 PM
"Heavy Duty" Springs listed on build sheet? IAJack TJ Wrangler Technical Forum 2 11-01-2005 05:53 AM
