Schaef's 89 YJ "build" - Page 11 - JeepForum.com
post #151 of 291 Old 11-16-2012, 08:27 PM Thread Starter
schaef89
Got these for a STEAL off Craigslist
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #152 of 291 Old 11-16-2012, 08:48 PM
jresch10
Are those Besttop seats?
2003 Liberty Renegade
2006 Grand Cherokee Laredo
2001 Cherokee Sport
jresch10 is offline
post #153 of 291 Old 11-16-2012, 08:58 PM Thread Starter
schaef89
Yes sir
schaef89 is offline
post #154 of 291 Old 11-16-2012, 09:10 PM
jresch10
Nice find!
2001 Cherokee Sport
jresch10 is offline
post #155 of 291 Old 11-17-2012, 01:55 AM
stratostix
I just spent the past hour reading your build/restoration. Looks like you've put a lot of hours into it. Thats great dedication. Good luck on the rest of your build. It's looking great so far!
1994 YJ
1965 Mustang Coupe Hi-po
2003 BMW 325i
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
Jeep Build thread:
stratostix is offline
post #156 of 291 Old 11-17-2012, 07:29 AM
soonermatt
These are the best kind. The wife generally approves of these purchases too. When I change my mind I can sell the stuff for cost or profit. I know the good feeling.
soonermatt is offline
post #157 of 291 Old 11-17-2012, 02:35 PM Thread Starter
schaef89
Got a bunch of work done today..
Got the seats installed! They are comfortable as hell. I was worried about then matching the interior but I think they look good
I moved on to spend some quality time with my intake and cleaned it up
Then onto cleaning the vacuum line assembly. Found a completely dry rotted hose as well and replaced it
The spring clip actually broke in two when I tried to remove it.. I wonder how long this hose has been there
I also degreased and de-rtv'd the valve cover in preparation for getting the head back next week. No pics of that though
schaef89 is offline
post #158 of 291 Old 11-17-2012, 02:41 PM Thread Starter
schaef89
Thanks! I've been following your 94 thread as well. Keep up the good work. Sometimes I wish I could do more modifications like you, but recently mine's been focused on creating a *working* jeep haha
schaef89 is offline
post #159 of 291 Old 11-17-2012, 04:11 PM
stratostix
I hear u. It all depends on what ur workin with. Thankfully my rust issues r minimal compared to urs. Ur definitely going in the right order. Cant be modding a rust bucket.
1994 YJ
2003 BMW 325i
Jeep Build thread:
post #160 of 291 Old 11-17-2012, 07:25 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Looked at the photos you posted up of your combustion chambers. Not sure why your #1 exhaust valve is so clean looking--only time I've seen that difference is if there has been coolant getting in there like in a blown head gasket, or a crack in the cylinder in that chamber. Of course, that doesn't seem to match your Intake valve in #1 so not sure what to make of it. Anyway, that's just an anecdote, and likely not the norm. I am sure the machine shop will test your head for cracks (pressure test, magnaflux) before they do a rebuild on it.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #161 of 291 Old 11-20-2012, 09:03 PM Thread Starter
schaef89
Got the head back today.. The machinist said he had to put 4 seats in and 3 completely new valves. He said it was real bad
No pics yet but I'll post some soon
schaef89 is offline
post #162 of 291 Old 11-21-2012, 07:07 AM Thread Starter
schaef89
So I think I heard the machinist wrong. Looking at it I think it was 4 new valves and 3 seats. Either way I stopped off at advance last night to get some engine paint to finish this off before I install.
schaef89 is offline
post #163 of 291 Old 12-02-2012, 09:29 PM
Craus
Impressive thread..thanks for all the pics and details of your work. Floors turned out great. I kind of thought you might have swapped your other jeeps engine after you pulled the head on the 4 cyl. But with these gas prices I wouldn't mind a 4 cyl right now myself
Craus is offline
post #164 of 291 Old 12-03-2012, 05:31 AM Thread Starter
schaef89
Thank you! I wasn't really thinking about that swap until i started having problems w the timing after i put the reman head in. Im still trying to track it down.. I even pulled the timing cover again to make 100% sure i did that right. I think I have it down to distributor position.
When i looked into using the 93 as a donor I wasn't too fond of the 32rh. If I didn't want to use it I would have had to find an ax15, computer, driveshafts, etc. Seemed like more work than I wanted to do in the winter, especially when I'll be moving into a new place in a couple months.
schaef89 is offline
post #165 of 291 Old 12-03-2012, 07:00 AM
responder
I read the entire thread this morning. Good job on your project! Chasing engine problems, or any problem for that matter, is never fun. Looks like you are getting a handle on it though.
responder is offline
LJ Build "Sylvia" another stretch on tons, COs, Hemi Swap-- EVENTUALLY VecoPlan TJ Wrangler Technical Forum 322 11-18-2013 09:20 AM
What could i build out of my broken hardtop? maybe a "hard" bikini top ..etc..?? BigDeaner YJ Wrangler Technical Forum 4 08-25-2010 11:00 PM
My Build, Best Money EVER Spent! 33" Rockers, 2.5" RC lift... rastaangel TJ Wrangler Technical Forum 1 04-11-2010 10:13 PM
Direction advice for my "newb" build from the experts outlanderbz TJ Wrangler Technical Forum 16 08-25-2009 07:05 PM
"Heavy Duty" Springs listed on build sheet? IAJack TJ Wrangler Technical Forum 2 11-01-2005 05:53 AM
