Schaef's 89 YJ "build" - Page 10 - JeepForum.com
post #136 of 291 Old 11-05-2012, 06:43 PM Thread Starter
schaef89
Bad news bears..
Ran another compression check with some unsettling results
#1 - 10 dry, 10 wet (no joke, checked it 7 times)
#2 - 110 dry, 130 wet
#3 - 60 dry, 65 wet
#4 - 110 dry, 140 wet
Only thing I've done to the jeep since the first compression test was seafoam it and replace the plugs.
I even let it run until warm and checked number 1.. Still 10. I pulled the plug wire and started it, and it ran like I never even pulled the plug wire. The plug looked like this after I shut it off for the night
Dripping gas.
The only thing I can think is that something happened in the head after I seafoamed it. The numbers point to the head as well for number 3.
The head will be coming off
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #137 of 291 Old 11-05-2012, 07:51 PM
Que89YJ
Not yet. Pull the valve cover first and check the valves lifters etc. first.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #138 of 291 Old 11-05-2012, 08:13 PM Thread Starter
schaef89
Have any advice on what to check? I know how they work just not good at diagnosing
schaef89 is offline
post #139 of 291 Old 11-05-2012, 08:27 PM
Que89YJ
As bad as you say it is it should be obvious. The valve will not be closing if it is a valve issue pull off the cover, remove the plugs and slowly turn the engine over with a wrench on the pully damper. Check the valves as it is turning. If it is a bad vavle it will be a broken spring or a bad valve either bent and not moving as much as the reset or a burned valve. You still might have a bad piston but you might luck out.
Que89YJ is offline
post #140 of 291 Old 11-06-2012, 07:17 PM Thread Starter
schaef89
Pulled the cover today. Found some white-ish stuff under the cover
I didn't see anything out of the ordinary. No bent pushrods or broken springs
I rotated it and watched the lifters and looked for valves to drop. I could see the intake valve come down but couldn't see the exhaust through the spark plug hole. Idk what else to do but pull the head and see for sure.
I did another comp test on that cylinder and got 15. I think it might be a burnt valve
schaef89 is offline
post #141 of 291 Old 11-06-2012, 09:52 PM
Schaef81
Seeing that you drive this thing....never...the white coloration in the oil could simply be condensation.
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline
post #142 of 291 Old 11-07-2012, 09:19 AM
Que89YJ
The white is too small of an amount, its condensation. If you cycled the engine through 1 rotation and looked at the intake and exhaust valves on the cylinder that gave you the bad readings it sould be obvious if they were stuck open. You are looking strait at them as they push and release. That leaves either a bad valve or bad rings.
Que89YJ is offline
post #143 of 291 Old 11-07-2012, 09:35 AM Thread Starter
schaef89
lets just hope it's not the rings. I should be pulling the head on friday so we'll see what surprises my jeep has in store then.
schaef89 is offline
post #144 of 291 Old 11-09-2012, 06:04 PM Thread Starter
schaef89
Pulled the head tonight and found this at the start. Can't tell if its old or gas but it smells like gas
Cylinders 1-4 in order.
3 has a sunken valve if you look close and 1 looks fried
Cylinders bores look real smooth and found my pistons are .030 over
And the head is ready for the machine shop (once I find one)
schaef89 is offline
post #145 of 291 Old 11-09-2012, 06:34 PM
jresch10
What kind of bike is that?
jresch10 is offline
post #146 of 291 Old 11-09-2012, 06:53 PM Thread Starter
schaef89
It's my buddy's ninja
schaef89 is offline
post #147 of 291 Old 11-11-2012, 09:16 PM
stmanser
I have read the entire thread you have on here, and I have been enjoying the progress you made, and the documentation of the floor project.
I bought my 88 YJ from a friend for $100. He was going to give it to me for free, and i told him I had to give him something for it.
Well it is a project itself. The floors are in bad shape. I have welded in most of the passenger side floor already, but i need to finish it off, and there is some body cancer, and some frame rot that i have not tackled yet.
I just bought a new house with a garage, and it is in the middle of the garage, ready to be worked on, just need to find the time here and there to work on it.
stmanser is offline
post #148 of 291 Old 11-12-2012, 09:17 AM Thread Starter
schaef89
Thank you sir! And congrats on getting your jeep.. seems you got a good deal regardless of throwing your friend a bill
I think i'm in the same boat as you about the jeep sitting around. I have a hard time juggling between jeep time and work a lot of the time actually
schaef89 is offline
post #149 of 291 Old 11-14-2012, 04:28 PM
stmanser
i need to rip off the old fender flares and fix the rot around the typical places and try and finish the floor. i will be doing that this thanksgiving break, i just hope i have time, without having to do something else for someone else.
lol
stmanser is offline
post #150 of 291 Old 11-16-2012, 12:09 PM Thread Starter
schaef89
Just dropped the head off at the machine shop. They said they should have it ready by next week
schaef89 is offline
LJ Build "Sylvia" another stretch on tons, COs, Hemi Swap-- EVENTUALLY VecoPlan TJ Wrangler Technical Forum 322 11-18-2013 09:20 AM
What could i build out of my broken hardtop? maybe a "hard" bikini top ..etc..?? BigDeaner YJ Wrangler Technical Forum 4 08-25-2010 11:00 PM
My Build, Best Money EVER Spent! 33" Rockers, 2.5" RC lift... rastaangel TJ Wrangler Technical Forum 1 04-11-2010 10:13 PM
Direction advice for my "newb" build from the experts outlanderbz TJ Wrangler Technical Forum 16 08-25-2009 07:05 PM
"Heavy Duty" Springs listed on build sheet? IAJack TJ Wrangler Technical Forum 2 11-01-2005 05:53 AM
