SBC wire conversion help - JeepForum.com
post #1 of 9 Old 10-23-2013, 09:43 PM Thread Starter
rollover755
I took out my 4.o and put in a SBC, does anyone know what wires i need to save to power my column and inside power?? I already know i need hot to coil and a starter wire but now i cant figure out how to get power back in Jeep...
rollover755 is offline
post #2 of 9 Old 10-24-2013, 08:10 AM
Que89YJ
Google is your friend:
http://www.jeepforum.com/forum/f12/f...oogle-1003734/
You get this list:
https://www.google.com/search?hl=en&...ng&safe=active
Are you using a stock wiring harness or are you using a painless? Do you have wiring diagrams for the SBC and the wiring harness you are using to wire? Do you have a multimeter to measure the voltages for rewiring?
Que89YJ is offline
post #3 of 9 Old 10-24-2013, 08:25 AM Thread Starter
rollover755
I'm going to try to use the Stock harness on the jeep, so all I need it the main power wires going from Battery to dash/firewall to power everything, from that point I can Find power and starter wires for Chevy motor. I've hooked up 2 main (red bigger wires) and still nothing....
post #4 of 9 Old 10-24-2013, 09:17 AM
SeanB95YJ
is it carbed or injected?
if it's carbed, it's just the coil hot, preferrably through a relay triggered by the key switch (yellow wire I believe) and the trigger wire for the starter (also through a relay, triggered by the key switch - brown?)
that and your grounds should get you at least running... then there's wiring for your gauges and such you'll need to hook up, but they're not NEEDED for initial start
if it's injected, then there are more wires, and it depends on which injection you have
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #5 of 9 Old 10-24-2013, 09:48 AM
YJames90
YJames90's Avatar
Theres a bunch of info and links to diagrams somewhere in my swap thread
My 2.5 to 4.3 swap thread
YJames90 is offline
post #6 of 9 Old 10-24-2013, 09:52 AM
Que89YJ
Here is a link with a real simple wiring diagram. You need to get power to the fuses
http://www.pirate4x4.com/tech/billav...20diagrams.pdf
You need power to your fuse block too.
Look at 5 to fire:
http://www.jeepforum.com/forum/f12/5...l-swap-357865/
Que89YJ is offline
post #7 of 9 Old 10-24-2013, 10:35 AM Thread Starter
rollover755
Thanks, I will for sure look over these diagrams.... Yes it is Carbed.. I know how to find the Coil and starter wire(test light) I just cant get power to my Firewall yet since i removed the harness and cut out all the injected wires...
post #8 of 9 Old 10-24-2013, 11:06 AM
Que89YJ
So you gutted the bulkhead connector before you figured out the power wires......oops!
Que89YJ is offline
post #9 of 9 Old 10-24-2013, 12:18 PM Thread Starter
rollover755
ummmmm, yea !! I guess i just figured the 2 bigger red wires were what i needed from Battery and then figured that is wouldn't be hard to figure out later, well here I am without power to tub.... I basically took the whole harness out on the bench and started cutting about everything... I dont want the fuse/relay box that is mounted near the battery, I just want to get power to the inner fuse box and steering column (so all my lights work) and then I can figure out the Hot wire for coil and starter wire.
