sattelite radios - JeepForum.com
post #1 of 24 Old 05-18-2006, 08:57 AM Thread Starter
scruffyjon
sattelite radios
I'm thinking of putting in a sirius stereo in my jeep, but not sure where the antenna should go. It's a plug-n-play radio, so I can take the radio with me, but I want the antenna to be permament. Any ideas where to install it so it doesn't look stupid?
/l ,[___],
l---L--[]lllllll[]-
()_) ()_)----)_)
scruffyjon is offline
post #2 of 24 Old 05-18-2006, 09:29 AM
bryris
I will be installing my XM soon and will have the same problem. I think that I will actually (not fully sure yet) install my antenna on the inside of the vehicle. Perhaps on that little ledge behind the rear seat. Could attach it to one of the roll bars back there. I dunno. Most people have cars and the typically spot is on the trunk door, up against the back window. But with a Jeep, if you put the antenna on the back hatch, you're signal will only work when driving in certain directions.
bryris is offline
post #3 of 24 Old 05-18-2006, 09:36 AM
blue1989yj
blue1989yj's Avatar
Maybe just behind hood vent in center. You could also try on the front windshield. I know that some car manufacturers are mounting them up there now.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline
post #4 of 24 Old 05-18-2006, 09:40 AM
pezley69
I have sirrius. I installed my attenae on top of my sound bar that is over my head. I just tucked it in the "wrap" that goes around it and ran the wires inside my roll bar covers. It works just fine. I think the higher the better. I would think on top of the roll bar somewhere would be perfect. I get great reception with the soft top on or off.
Hope this helps.
Pez
05 Black TJ Rubicon 2" Spring lift, Hella 500's on the windshield, SRC front bumper, SRC rear bumper w/ tire carrier, SRC rocker guards/steps, Mile Marker PE8000 winch
pezley69 is offline
post #5 of 24 Old 05-18-2006, 09:40 AM
EABiker
Since you do not have a metal roof, anywhere in the interior would work fine; the less visible from prying eyes, the better!
EABiker is offline
post #6 of 24 Old 05-18-2006, 10:54 AM
lutzke21
I placed my XM antenna on the very front of the driver's side roll bar. I'll try to get a pic later today. It's out of sight and the strong magnet holds it in place very well.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #7 of 24 Old 05-18-2006, 12:46 PM
vertresq
vertresq's Avatar
I ran mine through the firewall and placed it on the hood right in the center in front of the cowl vent. Works perfectly well, but I don't usually keep my XM in there unless I'm riding it, and then lock the head unit up in the center console to take it with me
Support Search and Rescue.... So that others may live....
93 YJ 6 cyl manual stock (almost)
99 Honda Accord
99 Acura TL
2006 Grand Cherokee Laredo
vertresq is offline
post #8 of 24 Old 05-18-2006, 12:53 PM
King03Kev
King03Kev's Avatar
1987 YJ Wrangler
Hey, recently in quadratec or 4wd they are selling satelite antenna mounts for roll bars that seem to mount to the main hoop with a velcro strap/magnetic mount. I think they were 19-20 dollars.
kevyj87 '87 I6 5spd, 215,000+ miles, Herced, Nuttered, Weber, HEI, RE 4", 1" BL, 4:11's, np231, 33x12.5's, SYE & shaft, 1" brown dog mm, home made bumpers front & rear, Ramsey 8,000lb winch
King03Kev is offline
post #9 of 24 Old 05-18-2006, 01:21 PM
Eric_D
My YJ had one installed in the same place when I got it. The wire then just runs down and through the firewall and comes out under the dash.
Eric_D is offline
post #10 of 24 Old 05-18-2006, 02:06 PM
raStapiMpjaY
I had mine mounted in several locations....
first, i went through the firewall into the engine bay and had it centered on the hood approx 6" in front of the back of the hood where it meets the firewall.... within minutes, DIASTER... the folding of the hood cracked the fiberoptics in the cable... had to get a new antenna
second, i just reandomly threw it on my rollbar (one of the side rear ones) as a temp measure cause i was going to install a tuffy and rerout everything.... it worked perfectly...
NOW, i have a rockhard4x4 cage with the front center overhead piece... it put it on top of that it is covered by padding & rollbar cover material and i have the wire run under the roll bar padding... PERFECT SIGNAL... even with a hardtop, softop and no top at all...
and the best part about this location... NOONE can tell i have Sirius sat radio... let alone a radio at all... i have an aftermarket headunit so i only had to get the Sirius converter box .... i put the stereo in the tuffy and the coverter box in the main tuffy unit itself... not one problem and its protected
and where the radio USED to be is just an empty spot with the factory wires just cut.... perfect theft deterent (plus the seats are black as is the tuffy so you dont even notice it)
raStapiMpjaY is offline
post #11 of 24 Old 05-18-2006, 04:14 PM
raysnutt18
raysnutt18's Avatar
I have XM and the place I put the ant. is up front on the hood where the hood ornament would normally be at....I ran the cable down the right side under the hood itself and then at the battery it drops down under the jeep where I punched a small hole up high in the passenger floorboard and then took it behind the A/C drain hose on the hump and then up next to the steering wheel
raysnutt18 is offline
post #12 of 24 Old 05-18-2006, 04:41 PM
sequel
I have mine on the sound bar underneath the flap over the passengers head. Works with the soft top on. Love having my sirius in my jeep.
1992 Black YJ, 4L I6, 8.8 Rear
3.5" BDS, 5/8" MORE Shackles,
DT-3000s, 16x8 Bajas,
285/75R16 Dunlop Mud Rovers
sequel is offline
post #13 of 24 Old 05-18-2006, 05:37 PM
jeeepguy
jeeepguy's Avatar
Top of the dashpad in the middle. Been there for over a year and works great. Even with my hardtop on.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #14 of 24 Old 02-04-2010, 04:57 AM
gmfcma
2016 JK Wrangler
gmfcma is offline
post #15 of 24 Old 02-04-2010, 05:06 AM
ssyj94
i put mine on the roll bar like everyone is ssaying but had terrible problems with signals fading out. Now its run through the firewall to the top of the hood cebtered between the washer sprayers. Never a problem with signal and you cant hardly notice it.
My build:
ssyj94 is offline
does anyone use cb radios anymore? neil11 TJ Wrangler Technical Forum 60 04-02-2011 07:50 PM
TEACH ME - CB and Ham Radios Woodchuck JK Wrangler Technical Forum 25 02-11-2010 05:13 AM
Anyone upgrade their radios? 17topless JK Wrangler Technical Forum 8 02-03-2010 02:01 PM
04 and 99 TJ Radios safarimike TJ Wrangler Technical Forum 4 08-24-2007 07:17 AM
TJ CB Radios, where did you mount yours? Pkibugu TJ Wrangler Technical Forum 10 08-13-2003 07:56 AM
