Same shocks when doing a 8.8?? - JeepForum.com
post #1 of 4 Old 01-23-2013, 08:50 PM Thread Starter
epettit
Getting everything ready to do the axle swap and was wondering I can use the same shocks as I have installed. I have a 4 inch leaf lift running skyjackers.
Ed Pettit
epettit is offline
post #2 of 4 Old 01-23-2013, 09:52 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
If you use a lower shock mount that accommodates being able to rotate it on the tube without the bushing binding to where it needs to be, you should be okay.
When doing so, make sure that the body of the shock does not contact the axle tube as the suspension cycles.
Joe Dillard is offline
post #3 of 4 Old 01-23-2013, 11:38 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Luck Favours The Prepared
Anticanman is offline
post #4 of 4 Old 01-23-2013, 11:49 PM
kirksjeep
I have the same tearaflex shock bar. Works great. I think M.O.R.E. makes upper mounts that go up and forward.
1992 YJ Sahara- 4.5" RE XD, 1" BL, 1" MML, 35" BFG MT, 8.8 w/Aussie, D30 w/Ten Factory shafts/ Aussie, 4:10 gears, Soild Diff Covers, SYE, CV Drive shaft, OBA, Flowmaster Super 44,, Custom head pipe, Super Chip, Boared out TB, Rock It Intake , Goferit Tie Rod Flip, 99+ intake manifold/Steering pump, custom front/rear bumpers,Hand Throttle, Hurst Shifter, Smitty Built sliders , 6" TJ flairs, Kilby belly up skid, Quadratech 9K winch, ZJ PS cooler. 01 XJ Sport-2" lift, 31x10.50 MT/ 02 Liberty 2" Lift
kirksjeep is offline
