Same old carb problems - Page 2 - JeepForum.com
post #16 of 44 Old 07-12-2011, 11:48 PM
monkeyhouse
Originally Posted by jth0033 View Post
The carb sound pass I believe, dunno that the shop would seriously notice the difference, only that it looks new. I know nuttering probably won't pass emissions, thats why I never did it. I think to get antiques in PA it has to be 25 years but only 15 for classic. Thing is I think they have driving regulations on them, and this is my DD
should that say, the carb should pass?
You won't pass emissions either way, this is something you should have researched before changing the carb. The carter would have passed emissions, but once you went to the mc, you put a carb in there that has no idea about the computer and the computer still thinks the carter is in there. So it will still control everything, this is why you do the nutter.
In md, they have driving regs too, but they are not checked at all. Best bet is to get the classic....in md, this allows you to modify anything, not sure on PA, but it has to be better than the regular.
I think you need to see just what your state inspects, sounds like you aren't very sure. If they inspect emissions, they don't just take a look at your carb, they actually test the output of your exhaust, what you are putting into the atmosphere.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #17 of 44 Old 07-13-2011, 01:20 AM Thread Starter
jth0033
1987 YJ Wrangler
Are you asking if they inspect emissions with or without classic tags? With classic tags I am only subject to an annual safety check, that is all. They say on the form to apply for classic tags that the vehicle should only be used once a week and not be for general daily transportation. As I said the carburetor will pass with the timing not messed with, that I am sure of. I just worry that if I nutter and the timing is changed, come time for emissions it won't pass.
Changing carburetors I knew this was going to be a problem, but I have until next March to get it all figured out. Still possibly looking to get a daily driver and then just use the Jeep as a fun vehicle, I just have to save up some cash.
jth0033 is offline
post #18 of 44 Old 07-15-2011, 08:47 PM Thread Starter
jth0033
1987 YJ Wrangler
Why wouldn't the mc pass emissions tho? I understand your saying they test the outputs and such but didn't this carburetor once pass on trucks that had emissions, why would it be any different? Interested to see if any PA guys can help me out here.
jth0033 is offline
post #19 of 44 Old 07-16-2011, 12:26 AM
monkeyhouse
Those trucks you mention had a system setup to take care of emissions, just as the carter did on your jeep. Honestly, I am not familiar with PA emissions testing, so I cannot say, but you have to keep in mind, you have removed a carb that was specifically setup to be emissions clean. The computer controls all those systems and works in conjunction with the carter. I know the weber has a conversion to use with the carter air cleaner system, but if you aren't finding something like that for the mc, it's a crapshoot. Again, I don't know your laws and i didn't go with an MC, hopefully someone can chime in who is more knowledgeable.
post #20 of 44 Old 07-17-2011, 10:05 AM Thread Starter
jth0033
1987 YJ Wrangler
bump
jth0033 is offline
post #21 of 44 Old 07-17-2011, 11:25 AM
csrcn2
you will pass emissions in PA. All you have is a visual inspection that they will check for EGR and pulse air system, just rig it up for the day. Doesnt have to be functioning just had to be present. I just bought the same carb from the same guy for my 89 YJ and its been a month and while it runs much MUCH better it still requires some fine tuning.
csrcn2 is offline
post #22 of 44 Old 07-17-2011, 05:25 PM
monkeyhouse
Great News, looks like you are all set!
post #23 of 44 Old 07-17-2011, 08:38 PM Thread Starter
jth0033
1987 YJ Wrangler
Well when it comes time I might have to figure out a way to rig up the pulse air, seeing that I capped that off haha. Thanks for the response. Looking to buy a vacuum gauge and timing light tomorrow to check and make sure everything is running smoothly.
Csrcn2: Have you nuttered your rig? Just curious.
jth0033 is offline
post #24 of 44 Old 07-17-2011, 09:45 PM
csrcn2
Yes I have
csrcn2 is offline
post #25 of 44 Old 07-17-2011, 10:03 PM Thread Starter
jth0033
1987 YJ Wrangler
Any way to conceal it? Just wondering cause that won't pass visual right?
jth0033 is offline
post #26 of 44 Old 07-17-2011, 10:53 PM
jhumphrey
This part is pretty easy to "hide", though I would never advocate doing something illegal, but this is how I made it all neat, which IS what I advocate
Open your loom that the original wires came from (leading to the dizzy), stick the "new" wires in that loom, and close her up. Since the nutter at the ICM is underneath the radiator reservoir and washer reservoir, I doubt anyone visually inspecting is going to look with that much detail in mind.
I dont have inspections where I am, but I couldnt imagine them being that detail oriented (well, maybe in CA).
Side note: did you ever get the carb running right? The photos that I had sent you were done via email communication to the jeep guy, so if they are wrong, I need to know to (and so does the jeep guy!)....
jhumphrey is offline
post #27 of 44 Old 07-18-2011, 08:10 AM Thread Starter
jth0033
1987 YJ Wrangler
Running right? Haha well it still needs some fine tuning but that's about all. My idle is a little low but I hope to nutter, set timing and use a vacuum gauge to get it all running right. Just a little tweaking and it should be good I hope.
jth0033 is offline
post #28 of 44 Old 08-02-2011, 05:33 PM Thread Starter
jth0033
1987 YJ Wrangler
Still haven't nuttered yet but noticed today that the engine seems to run better when its cold. what could this have to do with?
jth0033 is offline
post #29 of 44 Old 08-03-2011, 07:16 AM
csrcn2
Possible vacuum leak.
csrcn2 is offline
post #30 of 44 Old 08-03-2011, 07:17 AM
csrcn2
Check your charcoal canister and vacuum reservoir and all hoses. My charcoal canister was leaking bad when I changed out carb and nuttered
csrcn2 is offline
Carb problems liftd87wrangler YJ Wrangler Technical Forum 11 03-23-2010 01:47 PM
Carb problems??????? jpsmets YJ Wrangler Technical Forum 5 03-21-2009 09:33 PM
CARB Problems Jeepsburg YJ Wrangler Technical Forum 4 06-24-2008 07:21 PM
Carb Problems KeithG YJ Wrangler Technical Forum 14 03-20-2008 07:22 PM
Carb Problems Ares YJ Wrangler Technical Forum 9 03-01-2008 08:40 PM
