Same old carb problems - JeepForum.com
post #1 of 44 Old 07-10-2011, 09:30 PM Thread Starter
jth0033
1987 YJ Wrangler
Alrighty, well last month I decided to finally replace my pos carter with a newly rebuilt motorcraft carburetor offered from the guy on eBay. Had him deliver it with a new choke already installed for easy hookup. In the process I made sure to replace all of the vacuum lines. Also earlier this week I decided to do the Team Rush upgrade to help. Within the last few days though (even before the team rush) the Jeep has been running extremely rough under load. When coming to lights I am forced to shift it into neutral (automatic) to keep the idle up. Anyone have a clue what it might be???? Any help is greatly appreciated
jth0033 is offline
post #2 of 44 Old 07-11-2011, 12:21 AM
monkeyhouse
have you posed this question to the guy you bought it from? I understand he has great directions and support. I would start there.
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #3 of 44 Old 07-11-2011, 05:21 AM Thread Starter
jth0033
1987 YJ Wrangler
I have heard the same thing but figured I could get just as good or probably even better from my fellow jeepforum members
jth0033 is offline
post #4 of 44 Old 07-11-2011, 06:16 PM Thread Starter
jth0033
1987 YJ Wrangler
Emailed the guy tonight and I'm going to check the choke wiring tomorrow. Also gonna check for any leaks at the carb base. Anyone have any other ideas?
jth0033 is offline
post #5 of 44 Old 07-11-2011, 06:21 PM
giggityjeeper
vacuum leak somewhere is my guess
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #6 of 44 Old 07-11-2011, 06:23 PM
superj
me too
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #7 of 44 Old 07-11-2011, 07:32 PM
4.7stroker
Did you tune your idle mixture screws with a vacuum gauge?
Did you set your base timing to 8*btdc using a timing light?
Have you hooked your vacuum advance to Manifold vacuum NOT ported vacuum?
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #8 of 44 Old 07-11-2011, 07:50 PM Thread Starter
jth0033
1987 YJ Wrangler
Went out and checked tonight and couldn't find the culprit.
Dwyane:
I haven't checked the idle screws with a vacuum gauge.
Timing isn't set to 8* btdc, didn't know this needed to be done since I haven't nuttered
Here are some pictures provided by a fellow member as to how I have the carb set up. Does this seem to be correct?
jth0033 is offline
post #9 of 44 Old 07-11-2011, 09:31 PM
4.7stroker
You must nutter or the crippled computer will do what it likes to your timing.
Tune in this order.
At 750 rpm with vacuum advance disconected and plugged set your timing to 8*btdc.
Tune your idle mixture screws to maximum vacuum using a vacuum gauge. You must tune each screw the same amount. Wait 30 seconds between each adjustment. When you reach maximum vacuum screw each idle screw in 1/16 turn.
Hook your vacuum advance up to a Manifold vacuum source NOT ported vacuum.
You may now need to reset your idle rpms back to 750 rpm.
I always recheck I am at max vacuum - 1/16 turn and my timing is at 8* with vacuum disconected and plugged.
Without setting up right it will never run right and you will not be happy.
You can use a cheap vac gauge that is designed to be put in a gauge pod in the dash, just use some vac hose and you have a very useful tool. a halfway decent timing light costs $30, do not get one with an adjustable timing advance they will screw you up.
Dwayne
[url]
[url]
post #10 of 44 Old 07-11-2011, 09:38 PM
superj
that last bit, about the adjustable timing advance is so true. i have a craftsman with the adjustable and i am not sure its good. i have had it for 6 months and when i put it to zero and set the time to 8 degrees. i think its right so i set the light to 8 and check to see if the line is at zero, no go. its always at 3 or 4. makes me mad because its a heavy duty metal housed timing light.
so you can use any vacuum gauge to make the vacuum for the carb? i am going to look around and make one. i have not set mine up using your method because i don;t have a gauge but since its so easy, i will have ot get off my butt again and do it.
superj is offline
post #11 of 44 Old 07-12-2011, 08:15 AM Thread Starter
jth0033
1987 YJ Wrangler
Looks like I have some things to do then. After installing the carburetor I was nervous about doing the nutter since I didn't know if it would pass emissions and I have also never adjusted timing before, little hesitant about doing it seeing that I could really mess something up. Also have never set vacuum using a gauge, kinda learning everything as I go, and whereas its not difficult, I just need to find time since this is my DD.
jth0033 is offline
post #12 of 44 Old 07-12-2011, 08:29 AM
heyitslou
1987 YJ Wrangler
I'm with you buddy my rig is my DD as well. It really limits the projects you can get into. Installing a Carb is far more difficult than the Nutter and setting the timing you will do just fine.
heyitslou is offline
post #13 of 44 Old 07-12-2011, 02:28 PM Thread Starter
jth0033
1987 YJ Wrangler
Looks like I will be buying a timing light and vacuum gauge. Anyone know if I won't pass inspection/emissions with the timing set to 8*?
jth0033 is offline
post #14 of 44 Old 07-12-2011, 03:01 PM
monkeyhouse
Timing isn't the issue. I would seriously find out what kind of emissions testing you will have to go through. In Maryland, a vehicle is considered "antique" after 20 years and you can get appropriate tags. With these tags, no inspection is required. I don't know about PA though. If you find that you cannot pass emissions testing, you may want to consider re-installing the Carter for testing. I have seen a few posts from some folks out west who do this.
post #15 of 44 Old 07-12-2011, 10:52 PM Thread Starter
jth0033
1987 YJ Wrangler
The carb sound pass I believe, dunno that the shop would seriously notice the difference, only that it looks new. I know nuttering probably won't pass emissions, thats why I never did it. I think to get antiques in PA it has to be 25 years but only 15 for classic. Thing is I think they have driving regulations on them, and this is my DD
jth0033 is offline
Carb problems liftd87wrangler YJ Wrangler Technical Forum 11 03-23-2010 01:47 PM
Carb problems??????? jpsmets YJ Wrangler Technical Forum 5 03-21-2009 09:33 PM
CARB Problems Jeepsburg YJ Wrangler Technical Forum 4 06-24-2008 07:21 PM
Carb Problems KeithG YJ Wrangler Technical Forum 14 03-20-2008 07:22 PM
Carb Problems Ares YJ Wrangler Technical Forum 9 03-01-2008 08:40 PM
